03-03-2017, 06:55 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Philippines
Member: 306786 Status: Offline Sonork: 100.1596805 Thanks Meter: 516 | Ipad 2 wifi a1395 with 2 HDD need bypass icloud I want to know if possible to bypass icloud with this 2 hdd nand using ipbox v2??? pls advice... |
03-07-2017, 16:59 | #5 (permalink) |
Freak Poster Join Date: Dec 2002 Location: maroc nador Age: 46
Member: 18767 Status: Offline Thanks Meter: 44 | This model has 2 nands, and ipbox2 does not support this kind of nand, even if you test it, test will give you error, and it's not supported by this box, the only way is to change nand manufacture like toshiba and put new information.. Waiting support to add this type of nands in the next update. Sent from my SM-N9005 using Tapatalk |
The Following User Says Thank You to mafioso3 For This Useful Post: |
03-08-2017, 10:42 | #6 (permalink) |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | Best solution for you is the following. Buy an icloud free nand for an ipad 2 model (see aliexpress etc for this) Remove both nands and place one back on the main position (left side in your picture or most far away from cpu) |
