05-26-2017, 18:41 | #1 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2539136 Status: Offline Thanks Meter: 2 | ipad air 2 i tryed with some metods bud nothing, i buy a nand flex socket for check conections and is always the same error 4014 in 2 ipads, Please help |
05-27-2017, 03:08 | #2 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1872250 Status: Offline Thanks Meter: 33 | check the BootMode option on ipbox it has 3 options on 64bit nand on my case the 1st bootmode after reball,ipad recognized by itunes in dfu mode and after the restore the ipad was dead(no errors on restore) i use another nand IC from another ipad and it works(32gb) |
05-29-2017, 01:02 | #3 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
Maybe not a good solder joins or the 1.5 resistance the ribbon puts on, there are some very sensitive resistors to ground of just 1%+/- bet they have lots to do with this error. IOS 10+ is also checking for some hardware stuff and cable signal. I use low heat solder paste and when everything is working I re-ball with a higher melting solder paste. IP Box is a good Flash Nand programmer, just need a good documentation, but that is what this forum is all about right | |
