12-08-2018, 17:52 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Poland Age: 46
Member: 91143 Status: Offline Thanks Meter: 140 | iPad Air 2 activate problem I have a serial number mac wifi and bt read from another ipad nand. Uploaded to the second and attempted to activate. "ipad cannot be activated because the activation information could not be obtained from the device" Any suggestions |
The Following User Says Thank You to siwyqq For This Useful Post: |
12-09-2018, 22:20 | #2 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Congo Kinshasa
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 494 | You must first buy a new serial number ie (BT-WIfi-SN) and then changed the chip WIfi ic took the chip WIfi in iPad air 2 Wi-Fi no GSM only Wi-Fi and restoure with a new Serial Number Envoyé de mon SM-G531F en utilisant Tapatalk |
The Following User Says Thank You to bobo bokota For This Useful Post: |
12-11-2018, 16:18 | #3 (permalink) |
Member: 91143 Status: Offline Thanks Meter: 140 | That's not solution. I have two ipads both are A1566, from one i took nand, serial and mac wifi bt, placed into another and it won't work. |
12-12-2018, 18:26 | #4 (permalink) |
Freak Poster Join Date: May 2013 Location: Ortahisar
Member: 1929052 Status: Offline Thanks Meter: 22 | my problem is same i change serila number s wifi not working activation problem i think in ip box boot different from a1566 |
The Following User Says Thank You to omercsh61 For This Useful Post: |
12-14-2018, 17:32 | #5 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
If you went and got your self a programmer then you should know what to do. I'm not going to buy me a car without knowing how to drive, common sense | |
The Following 2 Users Say Thank You to cisco2017 For This Useful Post: |
12-15-2018, 09:55 | #6 (permalink) | ||
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
This device have IMEI number change wifi ic. | ||
The Following User Says Thank You to .:MobileLife:. For This Useful Post: |
12-18-2018, 16:09 | #7 (permalink) | |
The A1566 is the wifi only version... | |
The Following User Says Thank You to cisco2017 For This Useful Post: |
12-25-2018, 10:49 | #8 (permalink) | |
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 494 | Quote:
Envoyé de mon SM-N910V en utilisant Tapatalk | |
