10-24-2017, 08:03 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: PHILIPPINES/BRUNEI Age: 44
Member: 343232 Status: Offline Thanks Meter: 22 | ipad air activition error ios 11 i already did cloning serial,mac/bt add on working same model but not success still activition error.. i already copy old data to new nand serial change only still same... |
10-25-2017, 03:59 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: EGYPT Age: 39
Member: 1298774 Status: Offline Sonork: 100.1584126 Thanks Meter: 94 | 1st check bt&wifi address from ipad by connect it to 3u and read full info 2nd get orignal mac address for ipad by data backup from old ic or use gsx |
The Following User Says Thank You to MA7MOD_GSM For This Useful Post: |
10-25-2017, 16:38 | #3 (permalink) |
Member: 343232 Status: Offline Thanks Meter: 22 | but i already back up the old nand data and write back up into new nand only serial no.was edited...and already read it also full info on gsx..why it was still got activition error? by the way thanks for the reply i will do it again then i will post result.. |
10-27-2017, 17:41 | #4 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
IOS 11 now compares the processor ID with the sn, some how it looks like they been keeping that information but never used it because is a violation to the security of your device since that is what is being used to encrypt data. I wonder how a refurbished iphone / ipad gets a memory change or CPU replaced? some one has access to edit or inventory the new info. Edit: in theory you should be able to upgrade memory if you use the same SN on your original memory chip. | |
