05-02-2017, 07:43 | #1 (permalink) |
Junior Member Join Date: Aug 2006
Member: 337091 Status: Offline Thanks Meter: 2 | iPad2 iPBox V2 SD05105_016g not support iPBOx V2 ipad 2 A1395 two nand flash 2x16Gb = 32gb nand flash not support...help....! |
The Following User Says Thank You to Sessiz_Hayalet_ For This Useful Post: |
05-02-2017, 09:39 | #2 (permalink) |
Freak Poster Join Date: Sep 2010 Location: ČR
Member: 1388158 Status: Offline Thanks Meter: 30 | - The latest nand chip that is not supported by the programmer. - NAND chip is damaged. What is the designation NAND?( HT.............) Using iP BoX V2 software 5.2. |
The Following User Says Thank You to Tony2323 For This Useful Post: |
05-02-2017, 16:26 | #3 (permalink) | |
Member: 337091 Status: Offline Thanks Meter: 2 | Quote:
SanDisk SD05105 016G iPBox screen >>> Is reading Nand_Flash information... Nand_ID : 0x452D94827656 Nand_EXTEND_ID : 0x452D94827656 Nand_Information: zzzzzz Nand_Factory : SanDisk Nand_Name : SD05105_016G Nand_PAGE : 256 Nand_PAGE_Size : 8832 Nand_ECC_Size : 64 Nand_CE_Number : 2 Nand_PLANE_Count: 1 Nand_Capacity : 18522046464Byte/17664MB/17.66GB >>> Sorry !!! Not support this type of hard disk!!! >>> All operations are done... | |
10-26-2017, 10:56 | #12 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1321085 Status: Offline Thanks Meter: 0 | I was talking about reading the NAND (one NAND IC at time) and reconstructing the partitions/filesystem from the two NAND dumps thereafter (with software like R-Studio and similar that handle the HFS+ filesystem) Last edited by goatsrulez; 10-26-2017 at 11:03. |
