08-03-2016, 19:02 | #16 (permalink) |
No Life Poster Join Date: Sep 2007 Location: nigeria
Member: 581848 Status: Offline Thanks Meter: 119 | |
The Following User Says Thank You to ramsey1976 For This Useful Post: |
08-03-2016, 23:15 | #17 (permalink) |
Freak Poster Join Date: Nov 2012
Member: 1842399 Status: Offline Thanks Meter: 21 | i think in pakistan there is no official reseller where we buy this? also kindly tell us that is this tool can unlock iphon4,4s,5,5s,5c,6 etc... or only ipad mini? |
The Following User Says Thank You to _Ari3s_ For This Useful Post: |
08-04-2016, 04:18 | #18 (permalink) | |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Quote:
http://forum.gsmhosting.com/vbb/f937...ckage-2113604/ second is need watched this vedio http://forum.gsmhosting.com/vbb/11947415-post1.html | |
09-02-2016, 07:34 | #23 (permalink) |
Junior Member Join Date: Mar 2015 Location: tbilisi
Member: 2357447 Status: Offline Sonork: dosrun Thanks Meter: 1 | Backup/Write Hard Disk Data ( supports Full Flash Reading/Writing/Erasing) this function what does it mean ? can copy data from damaged hdd and copy it to another new hdd without lost data possible ? |
09-05-2016, 19:40 | #25 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2620498 Status: Offline Thanks Meter: 0 | HI, Why cant remove icloud from iphones if we can edit all info inside, as IMEI and other info? Didnt understand this part, can you explain. Im interested in buy the equipment but i didnt understand why i cant remove the icloud on iPhones. If i remove the NAND and change the IMEI as i remove the the CPU and read and Write the data, etc... Can you explain this part? |
09-06-2016, 18:17 | #26 (permalink) |
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Iphone is different with ipad ! If you want to remove icloud for iphone need to change 3 chip ic For ipad using ipbox v2 ... You just change SN only .... Done! |
The Following User Says Thank You to .::ARD::. For This Useful Post: |
