04-21-2017, 18:53 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: chenai,india
Member: 883886 Status: Offline Sonork: 1664059 Thanks Meter: 111 | iphone 6 error 9 need solution |
The Following User Says Thank You to mransar For This Useful Post: |
05-01-2017, 05:13 | #6 (permalink) |
Insane Poster Join Date: Feb 2017
Member: 2685790 Status: Offline Thanks Meter: 21 | Error 9 is CPU. Or I think over heated board(burned pads maybe)Not EPROM. if you think of it. You heat up board way to much because of thinking it's nand issue and end up burning up the CPU or pads somewhere on board. . If you keep heating board to much you'll damage it and end up with error 9. |
The Following User Says Thank You to Albo221 For This Useful Post: |
05-01-2017, 05:16 | #7 (permalink) | |
Insane Poster Join Date: Apr 2014
Member: 2171747 Status: Offline Thanks Meter: 10 | Quote:
Im sorry to say this but you're funny bro what you're saying is pure conspiracy! Sent from my iPhone using Tapatalk Pro | |
05-01-2017, 05:17 | #8 (permalink) |
Member: 2171747 Status: Offline Thanks Meter: 10 | iphone 6 error 9 need solution For the ones who want to fix error 9; Reflow anti-roll back eprom! 100000000000000% oh and don't forget to restore the phone on DFU mode after you reflowed it Sent from my iPhone using Tapatalk Pro |
05-01-2017, 05:48 | #11 (permalink) | |
Member: 2685790 Status: Offline Thanks Meter: 21 | Quote:
Saying why you'd receive error 9 from previous logic board I've delt with. And past post on here about ip box. 🔥Heating the board so many time damaged it. I've damaged boards from a stupid error 40s Witch later I found out when it was something as simple as not deleting everything on nand. Just changing sn and attaching back to board without restong with iTunes. Simply trying to say if you heat the board up 400+(Witch half of the new people with ipbox are doing) your going to burn it and end up with errors. | |
05-01-2017, 05:56 | #12 (permalink) |
Member: 2171747 Status: Offline Thanks Meter: 10 | Providing a fix: Reflow Anti-Rollback EPROM will solve error 9 Use the (not providing a fix ) message for reference of why the Anti-rollback eprom balls get damaged and need reflow ! And if it doesn't make sense why you need to do reflow to anti-rollback eprom go see schematics to see how it works that's it brah Sent from my iPhone using Tapatalk Pro |
05-01-2017, 10:56 | #14 (permalink) | |||
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | Quote:
take a look at my post fix some error including error 9 , this post is old post and i copy it from my original forum to share here so the other dont confuse http://forum.gsmhosting.com/vbb/f933...-done-2220088/ i know this guide will help you a lot, so do not hisetate to press the THANKS BUTTON | |||
The Following 4 Users Say Thank You to maxieboy For This Useful Post: |
05-01-2017, 13:18 | #15 (permalink) |
Member: 2171747 Status: Offline Thanks Meter: 10 | Lol when you reball the nand and put it back the eprom gets an automatic reflow lol I've already said "go take a look at schematics to see how it works" you can link me to 1000 post if you want! But all those can be useless if there's 1000 guessed solution to a single problem! Sent from my iPhone using Tapatalk Pro |
