02-15-2018, 17:48 | #1 (permalink) |
Junior Member Join Date: Nov 2008
Member: 901896 Status: Offline Thanks Meter: 1 | iphone 6 plus touch not working after replace nand I have a problem with iPhone 6 plus. this phone symptom touch not work after replacing nand memory flash. I already tried 2 times replaced new two touch ic (U2401, U2402). I am sure about no problem with touch ic (U2401,u2402) Do you have any idea about this problems? Thank you. |
The Following User Says Thank You to samson000007 For This Useful Post: |
03-02-2018, 20:11 | #3 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Macedonia Age: 43
Member: 10742 Status: Offline Thanks Meter: 13 | You have program nand with ip6 model. Be sure before proglam nand as ip6 plus model selected |
The Following User Says Thank You to cale For This Useful Post: |
03-07-2018, 11:33 | #5 (permalink) |
No Life Poster Join Date: May 2005 Location: UK
Member: 143848 Status: Offline Thanks Meter: 125 | Hang on... 1) If you see samller writing on iphone 6 plus screen. 2) touch also hard to use. have you connected the lcd and home button before restoring ? have you used iphone 6 plus tick in ip box before writing boot ? hope this helps. |
