03-25-2017, 02:36 | #1 (permalink) |
Insane Poster Join Date: Feb 2017
Member: 2685790 Status: Offline Thanks Meter: 21 | iPhone 6 stuck in dfu durning restore. Gives me error 4014 but won't kick out of dfu to follow threw with Restore on iTunes. Tried everything. Won't kick out of dfu mode. |
The Following User Says Thank You to Albo221 For This Useful Post: |
03-25-2017, 16:42 | #4 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2673576 Status: Offline Thanks Meter: 4 | Starting to sound more of a Nand issue. Check components around nand area or get a working nand from another device and try it. Without a Nand installed it will not get to recovery mode and will result in a continuous DFU. Did you try 3utools? It might get you a more direct input as to that 4014 error. |
03-25-2017, 18:37 | #5 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | error 4014 90% nand issue please check carefully and also the capacitor beside the nand |
The Following User Says Thank You to maxieboy For This Useful Post: |
03-26-2017, 00:19 | #6 (permalink) |
Member: 2685790 Status: Offline Thanks Meter: 21 | I removed c0634 but still same issue. It Doesn'trestore. 3utools says failed to connect device in recovery I'm scratching my head on this one. I tried a different nand. Still black screen stuck in dfu. |
03-26-2017, 22:57 | #9 (permalink) |
Member: 2685790 Status: Offline Thanks Meter: 21 | No. had error 4014. I did reflow and ended up with pmic getting really hot. So I seen cap c0634had a short. So I removed. And stuck in dfu with error 4014. It won't restore just sits at waiting for iPhone for a while and throws error 4014. So I still need help. |
04-04-2017, 16:14 | #12 (permalink) |
Member: 2685790 Status: Offline Thanks Meter: 21 | I ripped a pad under nand. And it's a short where that pad use to be. The solder mask is scrapped off and exposing the pcb bottom. It's shorting when I reflow nand to pcb spot. I have to wait for new solder mask paste and see if I can trace pin with magnet wire. |
04-25-2019, 12:30 | #13 (permalink) |
Insane Poster Join Date: Jan 2018
Member: 2797527 Status: Offline Thanks Meter: 4 | My iPhone is stuck in DFU mode last week and I used Joyoshare UltFix iOS System Recovery to fix it efficiently. There is no data loss. It also has a free feature to enter and exit recovery mode quickly with one click. |
05-02-2019, 21:36 | #14 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Congo Kinshasa
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 496 | Check line 1v8 Nand if is good remove nand solder well Because 1v8 not connect to nand I try iphone 6 plus Envoyé de mon SM-G850F en utilisant Tapatalk |
The Following User Says Thank You to bobo bokota For This Useful Post: |
