09-23-2017, 19:46 | #17 (permalink) |
Freak Poster Join Date: May 2016 Location: Colombia
Member: 2575005 Status: Offline Thanks Meter: 41 | And the worst thing is that nobody from IP BoX 2 support is pronounced. At least to see what solution you can have. Enviado desde mi iPhone utilizando Tapatalk |
09-24-2017, 01:45 | #20 (permalink) | |
Freak Poster Join Date: Dec 2000 Location: Belgrade, Serbia Age: 44
Member: 2768 Status: Offline Thanks Meter: 12 | Quote:
Cloning will be solution but the problem is: first device that is linked to an apple id will link all cloned devices. | |
09-24-2017, 01:45 | #21 (permalink) | |
Freak Poster Join Date: Jan 2013
Member: 1872250 Status: Offline Thanks Meter: 33 | Quote:
1 with physical damage icloud unlocked and 1 icloud locked the plan was to just take the nand from already unlocked physical damage ipad air,and place it on the locked but after read with ipbox i make damage on nand with reball so i use a new one and i place the backup of the the 1st boot1+boot2 the ipad is running now on ios 11 and its activated so my theory is....you need find original SN using serial number info checker with FMI OFF(i have only paid) and after that you need to take that SN and find all GSX PRO INFO to get the MAC again..you need the gsx PRO info not SOLDBY info Model: IPHONE 7 GSM 32GB BLCK IMEI: 3553210861XXX89 Serial Number: F18T8XXXHG7F Product IOS Version: 10.3.2 ICCID: 89300100160803215077 Mac Address: 886B6E523DEE Estimated Purchase Date: 03/31/17 Registration Date: 03/31/17 Warranty Status: Apple Limited Warranty Warranty Days Remaining: 191 Days First Unbrick Date: 03/31/17 Purchase Country: Hungary Initial Activation: 10 Unlock. Applied Activation: 10 Unlock. Next Tether: [COLOR=#1c699f !important]10 Unlock.[/COLOR] Unlocked: TRUE Unlock Date: 03/31/17 FMiP Status: ON | |
09-24-2017, 01:48 | #22 (permalink) | |
if you place it on GSX PRO checker you will find the mac so yes you will have the combination of mac+sn and have valid udid and no cloning need | |
09-24-2017, 02:02 | #23 (permalink) | |
And if you use that s/n on more then one device then all of the cloned devices will be locked with same icloud account. It can be a problem if you sold that device to someone. | |
09-24-2017, 02:52 | #24 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 42
Member: 103024 Status: Offline Thanks Meter: 616 | Quote:
UDID IS THE RESULT OF UDID = SHA1(serial + ECID + wifiMac + bluetoothMac) TALKING ABOUT IPAD , ON IPHONE UDID = SHA1(serial + ECID + wifiMac + bluetoothMac + IMEI ) HOW DO YOU PLAN TO CLONE ECID ? ECID IS TAKEN FROM CPU , AND IS UNIQUE IDENTIFIER , THE ONLY WAY TO CLONE IS BY CHANGING CPU FROM NON LOCKED BOARD , AND ALSO NAND WITH BT AND WIFI ADRESS SO , IN MY OPINION WE HAVE TO SEARCH FOR ANOTHER WAY TO TRICK APPLE TO ACTIVATE BYPASSED DECIVES | |
The Following 5 Users Say Thank You to rogerboogie For This Useful Post: |
09-24-2017, 03:02 | #25 (permalink) | |
If this is the case, and UDID is calculated from a ECID, and ECID cannot be the same on both devices, then UDID has nothing to do with this! Apple only then check if S/N matches Wifi and Bluetooth MAC. That can be the only logical answer... | |
The Following User Says Thank You to rango For This Useful Post: |
09-24-2017, 04:08 | #26 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Offline Thanks Meter: 174 | ios 11 is really givin a big headache modified nand not get activated. and also Read data from fmi unlocked I pad only can use one time. Its almost impossible to find fmi unlocked dumped i pads. might be the end of all nand I cloud unlocking.. |
09-24-2017, 21:32 | #28 (permalink) | |
my ipad air is a proof because the physical damage who i take the nand backup has different ECID from the locked ipad | |
09-24-2017, 22:10 | #30 (permalink) | |
Even if you change nand from unlocked iPad , when you mount on locked devices , the iOS 11 activation ticket Will be denied , since ECID comming from cpu Will modify udid final calculation | |
