Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > IP-BOX (The SMART Tool)
Old 11-05-2017, 05:45   #91 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
Originally Posted by cisco2017 View Post
If the site you got your IPBOX honors returns "DO IT ASAP"
All those "Nand Programmers" are useless now.
Others will claim other wise because they are in the business to sale and they and almost 100% have a + inventory on the boxes witch very much they can say good bye to their investment.
\ \\ AND who ever buys one even after reading this post are fools...
WHY: because in any case a work around is found a new tool will be sold, I'm sure the makers of these boxes want to make money too.
Fools? Nand programmers are not really intended for icloud removal hahahah— you are the idiot here if you think it is just for Icloud . BR
Sent from my iPhone using Tapatalk
The Following 2 Users Say Thank You to 1R0niC For This Useful Post:
Old 11-06-2017, 15:52   #92 (permalink)
Member: 2001933
Thanks Meter: 2
If I put iphone 5s nand, bb and cpu from iCloud free board to iCloud locked board will have some conflicts? iCloud free board have problem with some resistor and display is black. I don’t know who’s “serviced” the board before and I think it will be better to put on good not damaged board. It’s possible like I think? Or need something else?
Old 11-10-2017, 22:03   #93 (permalink)
Crazy Poster
Member: 2697189
Thanks Meter: 37
this is easy to test by fitting a genuine locked nand of course but should not work a UDID is a SHAH1 hash of serial, wifi,btooth and ecid as a string. the latter is not stored in nand!
This is an encryption problem. it activation lock no longer uses serial only the authentication with apple server is essentially looking at cpu key the on disk encryption uses the same key i believe.
Old 11-11-2017, 13:48   #94 (permalink)
Member: 1872250
Thanks Meter: 33
im looking for someone who can unbound the mac address on iphone 6s plus the device now is on ios 10.2 i know if it will be updated it will cant activate
but its better to fix it because actualy without wifi still cant activate on ios 11 so i will stop the ota update and the device will working
im preffer some guy in europe im in Greece
please send me pm with price
Old 11-14-2017, 14:15   #95 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
IP-BOX 2 semi-dead ? no updated to on 64bit devices
Old 11-14-2017, 15:01   #96 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 133
Many 64bit devices already supported like 5s 6 6p
Need new chips of 6s and up.
Old 11-22-2017, 00:28   #97 (permalink)
Member: 2484073
Thanks Meter: 14
Any one can be explain, how this guys can unlock iOS 11?
youtu. be / aciAyjZRhOU
Old 11-23-2017, 02:48   #98 (permalink)
Member: 1658652
Thanks Meter: 9
It's a fake video. This guy is struggling with his programmer and doesn't change any thing on nand.
Old 11-26-2017, 09:45   #99 (permalink)
Member: 2691507
Thanks Meter: 100
The "memory upgrade" is the "LEGAL" term to import the boxes.
Yes, you can upgrade NAND
Try to send one back to china and see if it will get there. it will be confiscated.
Old 12-10-2017, 01:25   #100 (permalink)
Crazy Poster
Member: 1036539
Thanks Meter: 4
ios 11 fix
there is new method friends, for some ipads on ios 11
Old 12-11-2017, 10:58   #101 (permalink)
Member: 1658652
Thanks Meter: 9
on ios 11 it is not possible for ipads to bypass icloud. The only way i think you can bypass is using hardware method first and than using some software to bypass it. i m not too sure this is just my assumptions.
Old 12-12-2017, 15:26   #102 (permalink)
Member: 1676470
Thanks Meter: 7
Originally Posted by janzir View Post
Hi,
When you were fixing your ipad air2, did you back up old nand data and put it on the new one, or you just programmed the nand coming from iphone 6 to ipad air2 format using your programmer ?
how to downgrad from 11.2??
Old 12-29-2017, 18:33   #103 (permalink)
Member: 1252523
Sonork: 100.1617870
Thanks Meter: 8
Hello
Now i have big problem after repair error 4013 with ip box i'm stuck in activation ios 11 i have payed for the check gsx Bluetooth address but gsx have saved my fake address generated with ipbox do u know any solution or how to find for the get old and good wifi address
Old 12-29-2017, 18:48   #104 (permalink)
Crazy Poster
Member: 1036539
Thanks Meter: 4
you erase your nand? what model of ipad is?
Old 12-29-2017, 18:49   #105 (permalink)
Crazy Poster
Member: 1036539
Thanks Meter: 4
yes you can! i sell method
Page generated in 0.25347 seconds with 8 queries
