Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > IP-BOX (The SMART Tool)
Old 09-21-2017, 20:01   #1 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 742
No more icloud remove after ios11
i face activation problem on 2 ipads
1.ipad air 2 replaced Nand from iphone 6
2.ipad air 1 convert 3g to wifi model
before was working with ios 10.3.3 after upgrade to ios11
get error on activation.....
again restore to 10.3.3 and acivated without any problem
1.
2.
3.
after downgrade to ios 10.3.3 its working......
1.
2.
The Following 3 Users Say Thank You to chand_gee For This Useful Post:
Old 09-21-2017, 20:46   #2 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 126
Yes its confirmed and tested.
Old 09-21-2017, 21:44   #3 (permalink)
GSMsurgeon's Avatar
Member: 6524
Thanks Meter: 241
I have updated via software update from ipad
Working fine ios11 .maybe problem via iTunes update
Old 09-21-2017, 22:02   #4 (permalink)
Moderator
Nizda Mobile's Avatar
Member: 1464783
Thanks Meter: 1,036
Yes... many tech got problem after ios 11... but not realy sure...
Need wait little time... maybe server update...
Nizda Mobile
Old 09-21-2017, 23:08   #5 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 742
There is no server problem...if you update via OTA then no issu on activation.
Butt after restore you cant activate any device with modified Nand ic
Old 09-21-2017, 23:23   #6 (permalink)
janzir's Avatar
Member: 1726910
Sonork: 100.1623945
Thanks Meter: 40
I just updated my 128GB iPhone 6SP to ios11 using itunes and i had no problem although my nand is modified , it was 16GB. I didn’t try restore ios
Sent from my iPhone using Tapatalk
Old 09-21-2017, 23:29   #7 (permalink)
janzir's Avatar
Member: 1726910
Sonork: 100.1623945
Thanks Meter: 40
1.
2.
3.
1.
2.
Hi,
When you were fixing your ipad air2, did you back up old nand data and put it on the new one, or you just programmed the nand coming from iphone 6 to ipad air2 format using your programmer ?
Old 09-22-2017, 02:56   #8 (permalink)
Member: 2575005
Thanks Meter: 28
I have not had any problems with IOS 11, all perfect. What I am thankful for is that up to now a moderator appears after so many users need help in this forum and not log on only with the help of maxie.
Old 09-22-2017, 07:56   #9 (permalink)
Member: 302596
Thanks Meter: 614
no doubt for it, just only the name but can't do the duty, poor user
The Following User Says Thank You to maxieboy For This Useful Post:
Old 09-22-2017, 14:25   #10 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 742
Originally Posted by janzir View Post
Hi,
the old nand was not supported with ip-box so cant read backup
and didn't program nand from iphone 6
just install and restore.......
Old 09-23-2017, 05:11   #11 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 29
So— iCloud remove is off for ipads ?
Old 09-23-2017, 09:44   #12 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 310
Yes You Are Right.......Now No More Hope Modify Serial No. Also What You DID Befoure Modify Sn They Will Also Come Icloued Lock When Customer update Iso11.
Old 09-23-2017, 09:46   #13 (permalink)
Member: 1658652
Thanks Meter: 4
No its not possible to unlock ipads on ios 11 any more.
Old 09-23-2017, 13:01   #14 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 394
Yes me also getting the same PROBLEM.. iPad AIR 2 after trying to flash 11.0
Old 09-23-2017, 16:51   #15 (permalink)
Member: 1872250
Thanks Meter: 26
i have found a theory who maybe its works,i clone a nand from hardware damage ipad air,and i put all the infos on another icloud locked ipad air
if it works i think maybe its gonna work if you are using the SN/MAC from already working machine...so you can get the mac address using gsx pro info,i will try it and i will post the result here
The Following 2 Users Say Thank You to xameleon7 For This Useful Post:
Page generated in 0.65221 seconds with 7 queries
