09-25-2017, 19:19 | #35 (permalink) |
Junior Member Join Date: Apr 2007
Member: 491701 Status: Offline Thanks Meter: 0 | Yes you can update to ios 11 over the interet. dont update with itunes. i just tried on ipad air with modified serial, when i try to restore ios 11 with itunes - cant get activated, but when i restore to 10.3.3 then activates with no problem. after activating 10.3.3 you can updete to ios 11 |
10-05-2017, 03:57 | #38 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Bye Bye iCloud bypasses...lost last hope.... Apple Stops Signing iOS 10.3.3 and iOS 11, Downgrades and Restores No Longer Possible... |
The Following 2 Users Say Thank You to chand_gee For This Useful Post: |
10-06-2017, 07:47 | #42 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: Hermanstadt RO
Member: 385881 Status: Offline Thanks Meter: 40 | Quote:
Maybe our hope is a way to spoof/clone ECID or make itunes believe we have a 32 bit idevice and rtestore with ios 10 activate and after update | |
10-06-2017, 09:52 | #43 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2705098 Status: Offline Thanks Meter: 6 | I understand that you can’t no longer take iCloud locked WiFi iPad by change the serial number to unlock as it won’t activate on iOS 11. Can you still take a cellular 3g or 4g iPad and remove the necessary resistors to iCloud remove or will this method not activate on iOS 11 as well?? Because with the cellular method you’re not changing the serial etc, you’re just changing the firmware. I got a iPad pro cellular and was wondering if to go ahead and try and iCloud remove by removing the resistors and bridging the other, can I still do this on iOS 11???jay |
10-06-2017, 11:37 | #44 (permalink) | |
tested! i have a theory to try to clone an already installed with ios10 nand to another and activating but didn;t succeeded so far to doa full dump | |
10-06-2017, 13:34 | #45 (permalink) |
Member: 2705098 Status: Offline Thanks Meter: 6 | what about memory upgrades, does that also fail to activate even if you just copy the data from then and on to a bigger and????jay thanks for the reply bastaphone. appreciate it.jay |
