Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > IP-BOX (The SMART Tool)
Old 01-17-2018, 21:13   #121 (permalink)
Member: 1861709
Sonork: 100.1647804
Thanks Meter: 8
is there anyone tried to buy SN-WIFI-BT and got it worked ?
Old 01-18-2018, 19:54   #122 (permalink)
Member: 1861709
Sonork: 100.1647804
Thanks Meter: 8
Conirmed the iPad worked after purchasing a new SN-WiFi-BT Mac addresses and wrote it to the Nand IC
Sent from my iPad using Tapatalk
Old 01-18-2018, 23:37   #123 (permalink)
Member: 2685790
Thanks Meter: 21
https://myicloud.info/hardware-icloud-removal-ios11/
There you go. Now we wait for Apple to patch this method now because everyone is finding out again!!!
Old 01-20-2018, 14:07   #124 (permalink)
Member: 2030266
Can i use serial from IPad 2 to IPad Air 2 ?
Old 01-20-2018, 19:31   #125 (permalink)
Member: 2685790
Thanks Meter: 21
Yes you can. As long as it's not iCloud locked. You also need MAC address, wifi, and bt of that serial number in the old one
Old 01-21-2018, 21:06   #126 (permalink)
Member: 2030266
Thanks for your answer. One more, can i use nand for iPhone 6 to IPad Air 2 wifi ? I do this and reprogrammed navipro but itunes gives error 40 .
Old 01-21-2018, 22:13   #127 (permalink)
Member: 1252523
Sonork: 100.1617870
Thanks Meter: 8
Error 40 no good solder
Envoyé de mon SM-G950F en utilisant Tapatalk
Old 01-23-2018, 23:02   #128 (permalink)
Member: 1768975
Sonork: 1615342:cikaaca
Thanks Meter: 50
What to do if i have ipad air mini 4 lte (with sim ) to bypass icloud
Old 01-23-2018, 23:28   #129 (permalink)
Member: 143848
Thanks Meter: 125
I have an iPhone 6 plus imei only the nand got damaged .. is there any way to retrieve other information i have imei and S/N available only.
regards
Old 01-24-2018, 20:39   #130 (permalink)
Member: 1861709
Sonork: 100.1647804
Thanks Meter: 8
Yes there is a paid service for this info
The Following User Says Thank You to Ghofran For This Useful Post:
Old 01-25-2018, 02:57   #131 (permalink)
Member: 2685790
Thanks Meter: 21
regards
You have to get a gsx service on the Imei or serial number
They should be able to give you your Mac,wifi, and bt
The Following User Says Thank You to Albo221 For This Useful Post:
Old 01-26-2018, 02:38   #132 (permalink)
Member: 143848
Thanks Meter: 125
i have managed to revive the 6 plus .. bought the service that told me the Serial number, wifi, and bluetooth address.. phone revived thanks all
The Following User Says Thank You to luckycool For This Useful Post:
Old 04-12-2018, 17:02   #133 (permalink)
Member: 2377800
Sonork: nono
Thanks Meter: 48
Yes you can use nand iphone 6 and write sn and wifi and bt is tested
Old 04-25-2018, 13:03   #134 (permalink)
Member: 2448477
Thanks Meter: 5
iPad Air 2 on Ios 9.3.3
Hi guys I already bypassed icloud 2 years ago using resistor method now my ipad working normally but on ios 9.3.3 with jailbreak. is there any way to update my ipad to ios 11 without stucking on activiation screen? can I backup my serial bluetooth and wifi data from ios 9? what do you recommened
Old 04-25-2018, 13:27   #135 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
yes you can update to ios 11 via OTA method
butt may be after upgrade your wifi not work
because ipadair2 bypassed with resistor method have wifi driver issue..
better dont touch it at this time and keep using on 9.3.3
Page generated in 0.21670 seconds with 8 queries
