pcıe harddisk repair problem >>> The user chooses to erase all data, delete the partition table and the underlying information.... >>> Is reading Nand_Flash information... Nand_ ID : 0xAD3A18A36125 Nand_Factory : SKhunix Nand_Name : H23Q1T8QK1MYS Capacity : 128G Capacity test : 159450660864Byte/152064MB/148.06GB >>> Found the hard disk with the same ID Nand_Factory : SKhunix Nand_Name : H23QFG8PG1MCS Capacity : 64G Capacity test : 79725330432Byte/76032MB/74.03GB >>> Found the hard disk with the same ID Nand_Factory : SKhunix Nand_Name : H23Q1T8QK2MY3 Capacity : 128G Capacity test : 159450660864Byte/152064MB/148.06GB >>> User selection: H23QFG8PG1MCS >>> Erase all content is Nand_Flash... >>> Erase all content is Nand_Flash... Bad block : 0x0007FC00...eeror Bad block : 0x00080000...eeror Bad block : 0x00080600...eeror Bad block : 0x00080700...eeror Bad block : 0x00081000...eeror Bad block : 0x00081100...eeror Bad block : 0x00081600...eeror Bad block : 0x00081700...eeror Bad block : 0x000B2E00...eeror Bad block : 0x000F7700...eeror Bad block : 0x00107800...eeror Bad block : 0x00107900...eeror Bad block : 0x00107A00...eeror Bad block : 0x00107B00...eeror Bad block : 0x00107C00...eeror Bad block : 0x00107D00...eeror Bad block : 0x00107E00...eeror Bad block : 0x00107F00...eeror >>> Erase all content is Nand_Flash... Bad block : 0x0007FA00...eeror Bad block : 0x0007FC00...eeror Bad block : 0x00080000...eeror Bad block : 0x00080600...eeror Bad block : 0x00081000...eeror Bad block : 0x00081100...eeror Bad block : 0x00081600...eeror Bad block : 0x00081700...eeror Bad block : 0x00091200...eeror Bad block : 0x000B8100...eeror Bad block : 0x000BE300...eeror Bad block : 0x000CE300...eeror Bad block : 0x000D0100...eeror Bad block : 0x000D2100...eeror Bad block : 0x00107800...eeror Bad block : 0x00107900...eeror Bad block : 0x00107A00...eeror Bad block : 0x00107B00...eeror Bad block : 0x00107C00...eeror Bad block : 0x00107D00...eeror Bad block : 0x00107E00...eeror Bad block : 0x00107F00...eeror >>> Erase all content is Nand_Flash... Bad block : 0x00053E00...eeror Bad block : 0x0007EA00...eeror Bad block : 0x0007EC00...eeror Bad block : 0x0007ED00...eeror Bad block : 0x0007FA00...eeror Bad block : 0x0007FB00...eeror Bad block : 0x0007FC00...eeror Bad block : 0x0007FD00...eeror Bad block : 0x00080000...eeror Bad block : 0x00080100...eeror Bad block : 0x00080600...eeror Bad block : 0x00080700...eeror Bad block : 0x00081000...eeror Bad block : 0x00081100...eeror Bad block : 0x00081600...eeror Bad block : 0x00081700...eeror Bad block : 0x00088500...eeror Bad block : 0x000BF100...eeror Bad block : 0x000D5400...eeror Bad block : 0x000EB000...eeror Bad block : 0x000F4A00...eeror Bad block : 0x00107800...eeror Bad block : 0x00107900...eeror Bad block : 0x00107A00...eeror Bad block : 0x00107B00...eeror Bad block : 0x00107C00...eeror Bad block : 0x00107D00...eeror Bad block : 0x00107E00...eeror Bad block : 0x00107F00...eeror >>> Erase all content is Nand_Flash... Bad block : 0x0007FA00...eeror Bad block : 0x0007FC00...eeror Bad block : 0x00080000...eeror Bad block : 0x00080600...eeror Bad block : 0x00081000...eeror Bad block : 0x00081100...eeror Bad block : 0x00081600...eeror Bad block : 0x00081700...eeror Bad block : 0x00097700...eeror Bad block : 0x000A7500...eeror Bad block : 0x000A7700...eeror Bad block : 0x000B3D00...eeror Bad block : 0x000C5C00...eeror Bad block : 0x000E6300...eeror Bad block : 0x000E7800...eeror Bad block : 0x000E7A00...eeror Bad block : 0x000EC000...eeror Bad block : 0x00107800...eeror Bad block : 0x00107900...eeror Bad block : 0x00107A00...eeror Bad block : 0x00107B00...eeror Bad block : 0x00107C00...eeror Bad block : 0x00107D00...eeror Bad block : 0x00107E00...eeror Bad block : 0x00107F00...eeror >>> Operations are done... >>> Is reading Nand_Flash information... Nand_ ID : 0xAD3A18A36125 Nand_Factory : SKhunix Nand_Name : H23Q1T8QK1MYS Capacity : 128G Capacity test : 159450660864Byte/152064MB/148.06GB >>> Found the hard disk with the same ID Nand_Factory : SKhunix Nand_Name : H23QFG8PG1MCS Capacity : 64G Capacity test : 79725330432Byte/76032MB/74.03GB >>> Found the hard disk with the same ID Nand_Factory : SKhunix Nand_Name : H23Q1T8QK2MY3 Capacity : 128G Capacity test : 159450660864Byte/152064MB/148.06GB >>> User selection: H23QFG8PG1MCS >>> Partition table file path: D:\İP BOX\system\pcie_boot\H23QFG8PG1MCS_6\ >>> Writing to partition table file.. Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... Erase: success... Write: success... >>> Total number of files written: 24 >>> Operations are done... >>> Initializing PCIe interface... Hard disk has been detected... >>> Initializing the hard disk... >>> Tip: This hard drive can be brushed normally... Capacity: 64GB Partition Table: nvme00 >>> Operations are done... |
