Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > IP-BOX (The SMART Tool)
Old 09-23-2019, 10:18   #1 (permalink)
Member: 706822
Thanks Meter: 427
pcıe harddisk repair problem
>>> The user chooses to erase all data, delete the partition table and the underlying information....
>>> Is reading Nand_Flash information...
Nand_ ID : 0xAD3A18A36125
Nand_Factory : SKhunix
Nand_Name : H23Q1T8QK1MYS
Capacity : 128G
Capacity test : 159450660864Byte/152064MB/148.06GB
>>> Found the hard disk with the same ID
Nand_Name : H23QFG8PG1MCS
Capacity : 64G
Capacity test : 79725330432Byte/76032MB/74.03GB
Nand_Name : H23Q1T8QK2MY3
Capacity : 128G
>>> User selection: H23QFG8PG1MCS
>>> Erase all content is Nand_Flash...
Bad block : 0x0007FC00...eeror
Bad block : 0x00080000...eeror
Bad block : 0x00080600...eeror
Bad block : 0x00080700...eeror
Bad block : 0x00081000...eeror
Bad block : 0x00081100...eeror
Bad block : 0x00081600...eeror
Bad block : 0x00081700...eeror
Bad block : 0x000B2E00...eeror
Bad block : 0x000F7700...eeror
Bad block : 0x00107800...eeror
Bad block : 0x00107900...eeror
Bad block : 0x00107A00...eeror
Bad block : 0x00107B00...eeror
Bad block : 0x00107C00...eeror
Bad block : 0x00107D00...eeror
Bad block : 0x00107E00...eeror
Bad block : 0x00107F00...eeror
Bad block : 0x0007FA00...eeror
Bad block : 0x00091200...eeror
Bad block : 0x000B8100...eeror
Bad block : 0x000BE300...eeror
Bad block : 0x000CE300...eeror
Bad block : 0x000D0100...eeror
Bad block : 0x000D2100...eeror
Bad block : 0x00053E00...eeror
Bad block : 0x0007EA00...eeror
Bad block : 0x0007EC00...eeror
Bad block : 0x0007ED00...eeror
Bad block : 0x0007FB00...eeror
Bad block : 0x0007FD00...eeror
Bad block : 0x00080100...eeror
Bad block : 0x00088500...eeror
Bad block : 0x000BF100...eeror
Bad block : 0x000D5400...eeror
Bad block : 0x000EB000...eeror
Bad block : 0x000F4A00...eeror
Bad block : 0x00097700...eeror
Bad block : 0x000A7500...eeror
Bad block : 0x000A7700...eeror
Bad block : 0x000B3D00...eeror
Bad block : 0x000C5C00...eeror
Bad block : 0x000E6300...eeror
Bad block : 0x000E7800...eeror
Bad block : 0x000E7A00...eeror
Bad block : 0x000EC000...eeror
>>> Operations are done...
Capacity : 128G
Capacity : 64G
Capacity : 128G
>>> Partition table file path:
D:\İP BOX\system\pcie_boot\H23QFG8PG1MCS_6\
>>> Writing to partition table file..
Erase: success... Write: success...
>>> Total number of files written: 24
>>> Initializing PCIe interface...
Hard disk has been detected...
>>> Initializing the hard disk...
>>> Tip: This hard drive can be brushed normally...
Capacity: 64GB
Partition Table:
nvme00
The Following User Says Thank You to mathew_di For This Useful Post:
Page generated in 0.19557 seconds with 7 queries
