07-22-2017, 20:33 | #1 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2558205 Status: Offline Thanks Meter: 8 | problem with ipad mini 4 after change nand i have problem with ipad mini 4 after change the nand to bypass icloud and upgrade all is okay but without WiFi MAC address mac is : N/A i already try to reprogram the nand but same problem please help me !! |
07-29-2017, 09:41 | #5 (permalink) |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Nand and wifi needs fixed on the Wifi/cellular version. The makes of the ipad are getting real nasty with the new updates and they are very often and all they do is check for hardware changes. what version of IOS you got? maybe you can jail break but make sure there is one for your version. if you are on the lates IOS no luck. |
07-30-2017, 20:53 | #7 (permalink) |
Freak Poster Join Date: Jan 2013 Location: socal
Member: 1866487 Status: Offline Thanks Meter: 113 | I have same issue now, iPad mini 4 a1538 Wi-Fi only device, removed SanDisk 128GB nand ic, changed serial number, restored via iTunes with 10.3.2, upon completion I receive the "problem with iPad". I've removed nand, erased all attached, restored and same issue 1. Could this be an issue with maybe gyroscope drivers or something because last time I had this problem was because I used nand ic from different device and solved my changing nand ic, but this time I used nand device came with Sent from my SM-G955U using Tapatalk |
07-31-2017, 16:29 | #8 (permalink) | |
Member: 1866487 Status: Offline Thanks Meter: 113 | Quote:
Sent from my SM-G955U using Tapatalk | |
08-09-2017, 04:04 | #9 (permalink) |
Member: 1866487 Status: Offline Thanks Meter: 113 | i think the problem is ip box not being able to properly program some sandisk nand ic, i have now 3 ipads all restore but start with there is a problem with this ipad and i JUST notice that all 3 are SanDisk 128GB. so im going to order 16GB from ebay for all 3. also i have a question, is it possible to fromat a random nand to work with whatver model you want or is there some underlying information that is specific to the nand and cannot be writtin from outside source |
08-09-2017, 04:38 | #10 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | Quote:
The Following User Says Thank You to maxieboy For This Useful Post: |
08-19-2017, 02:03 | #11 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Just want to share my experience yesterday i was change serial and everything is working it was Sandisk 128 gb. Sent from my iPhone using Tapatalk |
