Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Smart Watches > LG Smart Watches
LG Smart Watches LG G Watch , LG G Watch R
Old 11-26-2014, 03:44   #1 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
[RECOVERY][dory] TWRP 2.8.1.0 touch recovery [2014-10-29]
Team Win Recovery Project 2.x, or twrp2 for short, is a custom recovery built with ease of use and customization in mind. Its a fully touch driven user interface no more volume rocker or power buttons to mash. The GUI is also fully XML driven and completely theme-able. You can change just about every aspect of the look and feel.
Phone look:
Tablet look:
CHANGELOG for 2.8.1.0:
-MTP fixes and improvements - you can now copy zips to the root of storage - thanks to _that
-TrueType Font support - optional as it takes up a decent amount of space so may not be available on all devices - thanks to Tassadar
-Temperature support - thanks to bigbiff
-Various other bugfixes and tweaks
CHANGELOG for 2.8.0.1:
-Fix a bug that causes weird graphics glitches and touch issues
CHANGELOG for 2.8.0.0:
-Add MTP support to recovery thanks mostly to bigbiff with a little help from Dees_Troy
-Add command line capabilities - you can now execute various TWRP features via adb instead of the touchscreen
-Add support for color in the console and give error, warning, and highlight lines different colors
-Track backup and restore progress based on file sizes to provide a much more accurate indication of progress
-Improve handling of /misc thanks to mdmower
-Improve setting of time on Qualcomm devices thanks to [NUT]
-Allow using images on slidervalue GUI objects thanks to Tassadar
-Allow using variables and addition and subtraction in variables for easier theming
-Add support for 1440x2560, 280x280, and 320x320 resolutions and update 240x240
-Allow ui.xml file to include additional xml files to help break up the theme and make TWRP easier to maintain
-Other minor fixes and improvements
Over the course of the last year or so, bigbiff has worked to migrate various Java functions from Android's MTP implementation to bring you a fully C++ based MTP implementation that allows you to transfer files to both emulated storage and Micro SD cards. It's confirmed to work on various Nexus devices but we may have to make some changes on other devices to keep Windows happy. Windows is very picky about USB IDs and its drivers. We have tested it on Windows 7 and 8 as well as Ubuntu 14.04 Trusty. MTP is enabled by default, but we do toggle it off and on automatically during certain operations such as if you choose to wipe a storage partition. You can enable or disable MTP under the mount menu in TWRP. For more about what MTP is here.
Note: Due to a weird bug with our MTP setup, you cannot copy a zip file to the root of storage with Windows. You can change the .zip to something else like .txt and then copy it to the root and rename the file back to .zip once it's copied to the device. You can also copy the zip into any subfolder.
Command line support is also now available. You can perform various OpenRecoveryScript commands via the adb shell. Depending on what you are doing you may wish to do a "twrp set tw_mtp_enabled 0" and then reboot to prevent the MTP auto toggle from killing your adb interface. You can use this option to create and restore backups, wipe, install zips, and more. Via adb shell, type twrp followed by a space then enter the OpenRecoveryScript command and hit enter. Find more OpenRecoveryScript commands here.
CHANGELOG for 2.7.1.0:
-Add GUI option to change or repair file systems on individual partitions. The change is destructive so backup your data including internal sdcard first. This option should make it a little easier to migrate a device from ext4 -> f2fs, for instance. You will find this option under Wipe -> Advanced Wipe, then select only one partition and then press the Repair or Change File System button. If a developer has added f2fs support for your device and we don't have it in TWRP, please contact me via PM to arrange for it to be added.
-Various bugfixes to backup and restore
-Improvements to USB storage handling
-Added a class to search for files to make finding the correct brightness file automatic in most cases
DOWNLOAD:
Most devices can be updated quickly and easily with the TWRP Manager app:
Play Store Link
1) Install TWRP Manager from the Play Store
2) Open TWRP Manager and provide root permissions
3) Hit Advanced->Install Recovery
4) Verify the correct device name on your screen then press Install Recovery if the correct device is showing
OR:
You can find more information and download links on our website!
BUGS:
If you have found a bug, please consider posting it to our github issues log. It's pretty much impossible for us to keep up with the more than 40 threads that we have for the devices that we "directly" support. If you have a significant problem that cannot be answered in this thread, your best bet is to PM me directly, contact us via our website, or find us in our IRC channel below. If you see someone that's struggling, feel free to point it out to us. We need your help to help us keep track of all of our devices! Thanks!
SUPPORT:
Live support is available via #twrp on Freenode with your IRC client or just click this link.
The Following 3 Users Say Thank You to Braycel For This Useful Post:
Old 04-23-2021, 02:59   #2 (permalink)
Member: 2912146
Thanks Meter: 91
thank you very much.
Page generated in 0.14352 seconds with 9 queries
