Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Xolo
Old 12-09-2014, 03:24   #1 (permalink)
Member: 2307081
Unhappy xolo q1000 opus2
1):wprking firmware flashing tool
2):bricked phone
any body pls help
Old 12-12-2014, 03:25   #2 (permalink)
Member: 2307081
Originally Posted by aslm77 View Post
1):working firmware flashing tool
2):bricked phone
any body pls help
Hello everyone , I am totally bricked my q1000 opus2. firmware already downloaded , need the flashing tool which is working on win7. I am taking backup from stock recovery but it can't restore . Flashing system,data, boot,recovery in fast boot mode,but going in boot loop. So pls. Pls. Help me.
Old 12-14-2014, 09:03   #3 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
https://drive.google.com/file/d/0B1H...ew?usp=sharing
This is the downloaded for this model : if you have problems on win 7, just run it as administrator.
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
Old 12-15-2014, 02:33   #4 (permalink)
Member: 2307081
Thank you br Alex
HW_onekey downloader not work properly evenly run as administrator, i can't select path for file to flash and can't see the connected phone.I think phone partition has been totally wiped,error in fastboot mode "partition table dosen't exist". In recovery mode , " can't mount path partition formated". adb sideload work but can't push the file to internal partition. I think its totally bricked,no chance to recover. If any solution to recover pls. help.
Old 12-16-2014, 09:19   #5 (permalink)
moulnisky's Avatar
Member: 947561
Thank you br Alex
Try on any friend computer using win xp: if won't work this mobile will need jtag as unluckily you must init again the partitions on the mobile.
Normally this happens when someone format the mobile under windows when the boot area is getting seen as external drive.
Alex
Old 10-21-2015, 11:21   #6 (permalink)
Member: 1111169
Sonork: shaikhasif
hiiiii sir xolo q1000 opus2 how to flash please help sir
Old 07-19-2016, 14:16   #7 (permalink)
teletalk's Avatar
Member: 926215
Sonork: 100.1650776
Thanks Meter: 95
i have got solution solution for this tool because if you are not install a proper usb driver this tool not detect a phone please use yep usb drivers and do not press or hold any key for boot just a connect normal usb cable to phone
Old 07-19-2016, 14:27   #8 (permalink)
teletalk's Avatar
Member: 926215
Sonork: 100.1650776
Thanks Meter: 95
Q1000_Opus2_Driver
Page generated in 0.18367 seconds with 8 queries
