Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Xolo
Old 10-31-2014, 05:46   #1 (permalink)
Member: 1086393
Thanks Meter: 771
Xolo q2000L pattern lock, flashing failed!!
Hi,
I have one xolo q2000L , it has pattern lock , I try to flash but it stuck on 2% and stops , so I Disconnect the phone.
And again when I try to flash, the flashing process stuck on 0% .
Need help.
The phone doesn't turning on.
Old 11-01-2014, 11:45   #2 (permalink)
Member: 1086393
Thanks Meter: 771
Now When I flash with "Brcm_MultiDownloader_201" which is the original tool of this phone.
Phone turn on but LCD is in blue screen.
Flashing completed only in 1 minutes but normally broadcom flashing takes approx,4 min
At first I mistakely flash with different flasher version v1.4.5.0 "Brcm_MultiDownloader v1.4.5.0
And the phone goes dead.
Need help.
Old 11-10-2014, 10:43   #3 (permalink)
Member: 1050364
Thanks Meter: 162
Red face me too this problem pls help
Need help.
Old 01-14-2015, 07:53   #4 (permalink)
Member: 1761678
Sonork: 100.1615439
Thanks Meter: 370
iam also face same problem after flash lcd blank
Old 02-03-2015, 16:45   #5 (permalink)
PUNEET5154's Avatar
Member: 1023528
Sonork: 100.1594367
Thanks Meter: 1,376
Pls Use Xolo Q1000 Opus Tool And Post Result.,.. Because I Use Same File And XOLO Q1000 OPUS TOOL IN Q2000L NO ISSUE WITH DISPLAY..
Puneet5154
Old 02-05-2015, 09:45   #6 (permalink)
hitesh2000's Avatar
Member: 365730
Thanks Meter: 84
Puneet5154
link for opus tool
Old 02-05-2015, 09:59   #7 (permalink)
Member: 2340524
Thanks Meter: 27
https://drive.google.com/file/d/0B-u...hPa3N0NHc/edit
Old 02-07-2015, 08:46   #8 (permalink)
Member: 1076623
Sonork: 0554200
Thanks Meter: 2
use to new multi tool 2.3
Old 04-21-2015, 17:03   #9 (permalink)
Member: 1050364
Thanks Meter: 162
same problem iam use all version Toll no use display blank
Old 04-21-2015, 17:32   #10 (permalink)
Member: 1050364
Thanks Meter: 162
Originally Posted by supporter india View Post
wat is this file ? pls replay
Old 06-04-2015, 08:49   #11 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
Puneet5154
please share file which u used . and flash tool
Old 06-09-2015, 05:28   #12 (permalink)
Member: 1451558
Thanks Meter: 28
xolo q2000l flash after blue screen
Old 06-09-2015, 05:45   #13 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
same here i haven't got any solution ..please share if some one have
Old 07-08-2015, 14:30   #14 (permalink)
Member: 1323417
Sonork: 650150323
Thanks Meter: 61
same problem plzz help me any one have solution
Old 08-11-2015, 12:34   #15 (permalink)
Member: 2087320
Sonork: 100.1644649
Thanks Meter: 6
open rar file which u have download S017
Then open file in rar and rename only ill Q2000L
and extract, then select file in broadcom tool 201
and flash,
Done for me!!!!!
Page generated in 0.22598 seconds with 10 queries
