Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Xolo
Old 01-07-2015, 18:03   #1 (permalink)
amit_varietymob's Avatar
Member: 399228
Thanks Meter: 66
xolo q600s how to flash or disable xolo secure?
I have xolo q600s android version 4.4.2 software version _s019_12052014. It is locked with xolo secure. When i am flashing phone with brodcomm multiloader by pressing volume up and volume down keys my drivers are not installing . I already installed drivers from adb setup 1.4.2 and drivers witch came with firmware download pacakge. Still in device manager it is showing unkown device and unable to install drivers. Usb debugging option is also disable by xolo secure. Is there any way to give driver and flash this handset. Using windows 7 32 bit.. Masters please help.
Old 01-07-2015, 22:37   #2 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
same problem i face i m also cant flash this handset
Old 01-08-2015, 08:13   #3 (permalink)
Member: 399228
Thanks Meter: 66
I am trying to root this device but usb debuggig is off. How to root when usb debugging is off. Can anyone suggest me root software that can root xolo q600s when usb debugging is disable by xolo secure..
Old 01-10-2015, 12:14   #4 (permalink)
Member: 1417201
Sonork: 100.1626868
Thanks Meter: 32
what problem you faced in mobile it can flash very easy you want flash i can guide you
Old 03-06-2015, 08:12   #5 (permalink)
Member: 2354467
I am also facing same problem. Unable to disable xolo secure. Software updation is also not taking place. XOLO customer care employee have little knowledge and askin to replace the mother board. It will cost more than the mobile cost.
XOLO q600 is lying useless due to this problem.
Let me know, in case of any solution.
Old 03-21-2015, 22:26   #6 (permalink)
Member: 1942086
Thanks Meter: 13
Bro flash the phone....first format with og tool then flash...ur problem is solved...
Old 03-27-2015, 13:47   #7 (permalink)
Member: 2366499
Xolo q1000
I have xolo secure enabled and i forgot the patter lock and now i cant factory reset by vol+ power button b'coz of xolo secure but usb debbugging is on. If i root my phone. The problem will be solved?
Old 04-14-2015, 13:09   #8 (permalink)
Member: 998041
Thanks Meter: 2
Old 09-01-2015, 14:30   #9 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
u need to unlock bootloader before flashing....
Page generated in 0.18924 seconds with 8 queries
