Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Celkon
Old 08-22-2014, 13:07   #1 (permalink)
Member: 2133717
Thanks Meter: 3
celkon a35k pattern lock solution 100%
press volume up and power
now u see black display wait this is (safe mode)
now phone is on in safe mode now u see 5 option dont use it
slide upper option bar click upper right menu option
then click setting option showing like gears
go in more/about phone/click 7-8 times on build number
now developer option created
on the debugging mode
open volcano 2.6.2 select android tab select select shift mode to recovery
now u see android logo on phone push volume up ....... now u know what to do
wbr
Abhishek jain burari
The Following 3 Users Say Thank You to jain sahab For This Useful Post:
Old 08-23-2014, 13:16   #2 (permalink)
Member: 1283520
now u can enjoying
Old 09-02-2014, 07:04   #3 (permalink)
Member: 2050220
its not working i tried it
Old 09-20-2014, 14:27   #4 (permalink)
Member: 2133717
Thanks Meter: 3
i think is not try properly try own without risk
100% work
Old 11-13-2014, 09:38   #5 (permalink)
Member: 1733857
No need any tool boss power on mobile when logo appears press and hold volume down then release power when u see android logo pres volume up then do rest of the work.
Old 11-22-2014, 12:07   #6 (permalink)
chinnivardan's Avatar
Member: 892484
Sonork: not using
Thanks Meter: 916
this method done for me
hold power till logo
after logo hold volume down
and release power key
to see reset menu press vol key
Old 11-29-2014, 09:55   #7 (permalink)
Member: 1605724
Sonork: 591910
Thanks Meter: 12
this method only gmail accouont.pattern lock not ok
Old 12-04-2014, 07:18   #8 (permalink)
Member: 758749
Sonork: raja.svr.2005
Thanks Meter: 2
celkon a35k hard reset done...:)
tutorial:
!) first press power buton
2) within 2 sec after press volume down buton after release power buton
3) u see recovery logo after relese all keys once press volume down key
4) u see wipdata/factory reset press power key
fallow that instuction simple....
dont do flash save time..gud bye..urs raj
The Following 2 Users Say Thank You to raja.svr.2005 For This Useful Post:
Old 01-07-2015, 14:47   #9 (permalink)
alim3899's Avatar
Member: 503368
Thanks Meter: 25
celkon a354c hard reset haw to formet
Old 01-22-2015, 10:12   #10 (permalink)
Member: 1648285
Thanks Meter: 5
Not down its up
Originally Posted by raja.svr.2005 View Post
tutorial:
2) within 2 sec after press volume UP BUTTON after release power buton
IT WAS TESTED BY ME
The Following User Says Thank You to 24x7 For This Useful Post:
Old 01-22-2015, 10:17   #11 (permalink)
Member: 1648285
Thanks Meter: 5
Not down its up
tutorial:
( NOTE :WIPE DATA RESET TAKES 3 - 5 MINITES DONTWORRY )
IT WAS TESTED BY ME
Old 02-02-2015, 10:25   #12 (permalink)
Member: 2339377
how to unlock pattern for celkon a66
Give me some suggessions for how to unlock pattern for celkon a66
Old 02-04-2015, 06:08   #13 (permalink)
Member: 892484
Sonork: not using
Thanks Meter: 916
no hardreset solution for celkon a66
only do flashing
Old 02-28-2015, 14:07   #14 (permalink)
satyakv's Avatar
Member: 1265967
Thanks Meter: 226
it's working my problam slove thanq
Old 03-01-2015, 16:57   #15 (permalink)
Crazy Poster
Member: 1979926
Thanks Meter: 3
celkon a35 k hold power key + volem + andrid loge 10000 ok
Page generated in 0.20936 seconds with 8 queries
