Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Celkon
Old 03-04-2015, 07:23   #16 (permalink)
Quadri s.i's Avatar
Member: 1982397
Thanks Meter: 17
celkon a35k hard reset done...
tutorial:
!) first press power buton
2) within 2 sec after press volume down buton after release power buton
3) u see recovery logo after relese all keys once press volume down key
4) u see wipdata/factory reset press power key
Old 03-18-2015, 07:03   #17 (permalink)
Member: 533997
Thanks Meter: 4
vol up is correct,thanksssssssssssssssssssssss
Old 03-27-2015, 17:15   #18 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 426
Thumbs up This Method Working Well
1) first press power button
2) within 2 sec after press volume UP BUTTON after release power button
3) u see recovery logo after release all keys once press volume down key
( NOTE :WIPE DATA RESET TAKES 3 - 5 MINITUES DONT WORRY )
Old 04-25-2015, 16:46   #19 (permalink)
cellcare prasad's Avatar
Member: 602547
Sonork: 100.1621466
Thanks Meter: 930
Originally Posted by jain sahab View Post
press volume up and power
now u see black display wait this is (safe mode)
now phone is on in safe mode now u see 5 option dont use it
slide upper option bar click upper right menu option
then click setting option showing like gears
go in more/about phone/click 7-8 times on build number
now developer option created
on the debugging mode
open volcano 2.6.2 select android tab select select shift mode to recovery
now u see android logo on phone push volume up ....... now u know what to do
wbr
Abhishek jain burari
100% working solution
Old 07-24-2015, 05:36   #20 (permalink)
abubaker773's Avatar
Member: 1811976
Sonork: abubaker773
Thanks Meter: 38
2) within 2 sec after press volume UP BUTTON after release power buton
( NOTE :WIPE DATA RESET TAKES 3 - 5 MINITES DONTWORRY )
IT WAS TESTED BY ME
thanks bro 1000% working
Old 08-02-2015, 09:17   #21 (permalink)
Member: 905341
Thanks Meter: 998
thanks working 100000000%
Old 08-28-2015, 11:14   #22 (permalink)
Member: 1569164
Thanks Meter: 2
celkon a35k hardreset by sameerjilany a2z mobiles madanapalle
a 35k hardreset hold power button + volume down until celkon logo apears
when logo appears release power button and continue volume down until options of wipe data apper then use volume up down for selection and power button for confirmation
enjoy correctly 100 % by GS Samiulla madanapalle a2z mobiles and institute
Old 08-31-2015, 14:19   #23 (permalink)
rajkumak's Avatar
Member: 1359361
Sonork: 12345
Thanks Meter: 57
power+vollup next reset 100% tested
Old 09-19-2015, 15:18   #24 (permalink)
Member: 2091370
Hello Team can u help me plz here one celkon A35K dual sim not working only one sim working , in sim management menu one sim option only enable other sim type not shown wat can i do
Old 10-04-2015, 06:56   #25 (permalink)
Member: 2046737
Thanks Meter: 3
celkon a35k dead No power on help pls...!!!
Old 11-13-2015, 10:03   #26 (permalink)
Member: 1584831
Thanks Meter: 46
done .nice solution..........
Old 12-22-2015, 02:03   #27 (permalink)
Member: 611274
Smile woking solution
thanks solution worked for me
Old 12-28-2015, 14:36   #28 (permalink)
Member: 1039668
Sonork: a small dot on forhead
Thanks Sir.
its working.
Old 12-28-2015, 16:16   #29 (permalink)
jorj_saha's Avatar
Member: 1649620
Sonork: 100.1603891
Thanks Meter: 177
CELKON Q450 HARD RESET
1)Volume Down + Volume Up + Power button
2) Now you are in Android Recovery System and see 4 different option.
3) To Scroll up don you have to press volume up button or volume down button
4) Select Wipe/Data Factory Reset
5) To confirm you want to erase data press the power button
- See more
Old 02-04-2016, 07:22   #30 (permalink)
Quadri s.i's Avatar
Member: 1982397
Thanks Meter: 17
celkon a66 gmail lock remove success by miracle box
Connecting to Phone,Wait..ok
Wipe data...
Need Root.
Abort by User
Definition Applied
checking info...
Rooted.
Definition Applied
Wipe data...
>>Done
Page generated in 0.23593 seconds with 8 queries
