08-22-2014, 13:07 | #1 (permalink) |
Junior Member Join Date: Feb 2014 Location: INDIA
Member: 2133717 Status: Offline Thanks Meter: 3 | celkon a35k pattern lock solution 100% now u see black display wait this is (safe mode) now phone is on in safe mode now u see 5 option dont use it slide upper option bar click upper right menu option then click setting option showing like gears go in more/about phone/click 7-8 times on build number now developer option created on the debugging mode open volcano 2.6.2 select android tab select select shift mode to recovery now u see android logo on phone push volume up ....... now u know what to do wbr Abhishek jain burari |
The Following 3 Users Say Thank You to jain sahab For This Useful Post: |
08-23-2014, 13:16 | #2 (permalink) |
Junior Member Join Date: Apr 2010 Location: london
Member: 1283520 Status: Offline Thanks Meter: 0 | press volume up and power now u see black display wait this is (safe mode) now phone is on in safe mode now u see 5 option dont use it slide upper option bar click upper right menu option then click setting option showing like gears go in more/about phone/click 7-8 times on build number now developer option created on the debugging mode open volcano 2.6.2 select android tab select select shift mode to recovery now u see android logo on phone push volume up ....... now u know what to do now u can enjoying |
11-22-2014, 12:07 | #6 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Hyderabad INDIA
Member: 892484 Status: Offline Sonork: not using Thanks Meter: 916 | Quote:
hold power till logo after logo hold volume down and release power key to see reset menu press vol key | |
12-04-2014, 07:18 | #8 (permalink) |
Insane Poster Join Date: Apr 2008 Location: india
Member: 758749 Status: Offline Sonork: raja.svr.2005 Thanks Meter: 2 | celkon a35k hard reset done...:) tutorial: !) first press power buton 2) within 2 sec after press volume down buton after release power buton 3) u see recovery logo after relese all keys once press volume down key 4) u see wipdata/factory reset press power key fallow that instuction simple.... dont do flash save time..gud bye..urs raj |
The Following 2 Users Say Thank You to raja.svr.2005 For This Useful Post: |
01-22-2015, 10:12 | #10 (permalink) | |
Major Poster Join Date: Sep 2011 Location: HYDERABAD
Member: 1648285 Status: Offline Thanks Meter: 5 | Not down its up Quote:
!) first press power buton 2) within 2 sec after press volume UP BUTTON after release power buton 3) u see recovery logo after relese all keys once press volume down key 4) u see wipdata/factory reset press power key IT WAS TESTED BY ME | |
The Following User Says Thank You to 24x7 For This Useful Post: |
01-22-2015, 10:17 | #11 (permalink) | |
!) first press power buton 2) within 2 sec after press volume UP BUTTON after release power buton 3) u see recovery logo after relese all keys once press volume down key 4) u see wipdata/factory reset press power key ( NOTE :WIPE DATA RESET TAKES 3 - 5 MINITES DONTWORRY ) IT WAS TESTED BY ME | |
