Celkon A9+ pattern lock solution plz Need Hard reset solution or how to flash i download flash file but boot key not working this phone plz help me any body thanks in advance |
i have also same problem |
U have USB Driver for A9+ Quote:
U have USB Driver for A9+ |
celkon A9+ Quote:
100% solve your problem. if you are faceing any problem,contact me.;) |
use volcano ver 2.1.3 , select spd 6820/8810 , tick format and run |
use :Dragon Box here done log >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM222 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:000098BC Flash Size:20000000->512M Flash Name:NAND_TOSHIBATYBC0A111236KC10 CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
sir.......... celkona9+ how to cenect on pc.......i tryd v-,v+ keys.....but ph. will be charging.........plz help me |
Vcc: null Gnd: 20 Analyzing D+ and D-... D+ = 22, D- = 23 Analyzing USB device, please wait... Find USB device:SCI USB2Serial (COM49), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 215m(system),175m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic) Analysis flash internal data successfully. >>Set to Factory successfully. DONE BY DRAGON |
but my box not ditected........ plz add link for A9+ usb drivers |
Download Driver From Here SCI-android-usb-driver-jungo-v4.rar B.R., Prem_India |
use SPD modified cable to flash Celkon A9+ see here for cable http://forum.gsmhosting.com/vbb/f457...l-cpu-1653937/ |
i hv celkon A9+ plz tell me how to pattern unlock it plz send me sloution |
thanks for modified cable work very well no need any boot key |
sucsses full in gpg 3.38 >>> Getting Mobile Connection Info.. VCC Pin: GND Pin: Signal Pin:1, 2, 3, 4, 5, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM82 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:000098BC Flash Size:20000000->512M Flash Name:NAND_TOSHIBATYBC0A111236KC10 CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
