Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Celkon
Old 03-24-2013, 14:01   #1 (permalink)
chinnivardan's Avatar
Member: 892484
Sonork: not using
Thanks Meter: 868
[Guide] All Celkon Mobiles Hard Reset Procedures
Celkon A97i Hard reset
Uploaded with ImageShack.us
Step
1.Hold the Volume up button then Keep Pressing Power button
still show android logo
2.ofter show android logo release two buttons
3.press home button menu will appears
4.to scroll menu use volume keys
5.to select use options key
The Following User Says Thank You to chinnivardan For This Useful Post:
Old 04-18-2013, 09:21   #2 (permalink)
sunil002's Avatar
Member: 1212786
Sonork: 100.1626896
Thanks Meter: 18
celkon A95 Pro Hard Reset Procedure
1.Press and hold down volume up + power button.
2.Android logo will appear.
3.Press home button
4.Options will be displayed
5.Select wipe data/factory reset using options key (second right or third left button)
Now reboot u r phone.
All done
Old 04-21-2013, 16:47   #3 (permalink)
Member: 892484
Sonork: not using
Thanks Meter: 868
Hi,
Please post here all the Celkon mobiles hard reset procedures
Celkon A95 Hard reset :
Process#
1.press volume down and power
2.release two buttons ofter see celkon logo
3.and press volume up key for one time (must be press volume up key before 3 sec ofter see the logo)
4.ofter that andriod logo appears
5.to see andriod secrete menu press home key
6.to scroll use volume keys
7.to select press options key
see picture
Old 06-21-2013, 18:18   #4 (permalink)
Member: 1149197
Sonork: prateet
Thanks Meter: 41
Celkon A59 Hard Reset Solution
[IMG]http://3.bp.********.com/-L0-CS1vGo5I/UcLrlgYUdiI/AAAAAAAAEnk/fDxe6cWg6EM/s1600/cellcon+a59+hardreset+solution.jpg[/IMG]
Here Are The Steps Of Hard Reset:
1.Hold The Volume Down + Power Button
Still Show Factory Mode
2.After Show Factory Mode Release Two Buttons
4.To Scroll Menu Use Volume Keys
5.Select Clear Flash By Volume Button
Phone Will Restart Hard Reset Done
Old 08-10-2013, 10:58   #5 (permalink)
Member: 1030555
Sonork: ********
Thanks Meter: 24
How to remove pattern Unlock celkon A9+
The Following User Says Thank You to yuganta For This Useful Post:
Old 08-20-2013, 10:18   #6 (permalink)
Member: 1668548
Sonork: 100.1647046
Thanks Meter: 23
Talking
ineeed the same plz send immed
The Following User Says Thank You to rajkilotra For This Useful Post:
Old 08-23-2013, 14:14   #7 (permalink)
Member: 1235107
Thanks Meter: 3
it is not working sir
The Following User Says Thank You to hampi_ss For This Useful Post:
Old 08-24-2013, 19:15   #8 (permalink)
Member: 2009970
My celkon a9+ handset getting restart can u tell me what is the problem
The Following User Says Thank You to CHANDARADARSHAN For This Useful Post:
Old 08-25-2013, 13:34   #9 (permalink)
Member: 1982129
How To Hard reset celkon A9+ plzzzzzzzzzzzzzz help me
The Following User Says Thank You to sujay.mobilesSV For This Useful Post:
Old 08-30-2013, 15:37   #10 (permalink)
FORUM-FON's Avatar
Member: 1832100
Thanks Meter: 55
Originally Posted by pooja goyal View Post
calkon a9+ successfully format with volcano box
Connecting...
Connection successful,connected state!
Version: V3.8
SN:140-664-900
Port:COM6
After format or Flash you have to press & hold power button for at least 1.30 mins.
Note for win7 users :
Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'.
After that the spd drivers will have the ability to be loaded.
Available Ports:COM1 COM3 COM6 COM11 COM12
Detection initiated...
Vcc: null
Gnd: 5
Analyzing D+ and D-...
D+ = 3, D- = 2
Analyzing USB device, please wait...
Find USB device:SPRD U2S Diag (COM53), (VID_1782&PID_4D00)
Internal version: SPRD3
Boot downloaded.
Start boot please wait a moment....
Spreadtrum Boot Block version 1.1
Boot downloaded.
CPU TYPE:SC8810/6820 [88100001]
Flash ID: 009800BC90667600
Flash Type:[TOSHIBA] TYBC0A111236KC10
FLASH LEN:0x20000000
mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 215m(system),175m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic)
Analysis flash internal data successfully.
Vcc: null
Gnd: 5
D+ = 3, D- = 2
Boot downloaded.
Boot downloaded.
>>Set to Factory successfully.
Witch is The Boot key Bro
Pls Share Step by Step Tutorial ..!
The Following User Says Thank You to FORUM-FON For This Useful Post:
Old 08-30-2013, 16:15   #11 (permalink)
deepuknp's Avatar
Member: 610829
Thanks Meter: 18
how to hard reset celkon a8+
The Following User Says Thank You to deepuknp For This Useful Post:
Old 08-31-2013, 09:31   #12 (permalink)
Member: 1668548
Sonork: 100.1647046
Thanks Meter: 23
Wink it can be unlock with volcano box not with hard reset ......there is no any hardres
it can be unlock with volcano box not with hard reset ......there is no any hardrest process
Old 12-21-2013, 07:57   #13 (permalink)
Member: 2089082
Thank you so much for this help. My phone just constantly restarts powers down and back up constantly. I wish to share the all celkon mobiles hard reset procedures which are running an online portal of mobile procedures where you able to find setting, privacy restore factory settings. Its easy to use.
Thanking you
Quantel
Old 01-03-2014, 04:02   #14 (permalink)
Member: 2097723
can i have download mode deatails of celkon a225??
Old 03-12-2014, 10:18   #15 (permalink)
Member: 1354113
Thanks Meter: 323
how to flashing celkon a87 dead condition plz help ineed flash fille, Internal version: SPRD3
Boot downloaded.
Boot downloaded.
CPU TYPE:SC8810/6820 [88100040]
Flash ID: 002C00BC90555600
Flash Type:[Micron] MT29C4G48MAZAPAKD
Page generated in 0.94587 seconds with 7 queries
