05-12-2016, 20:06 | #1 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1397982 Status: Offline Thanks Meter: 44 | Intex Aqua 3G Dead Recovered Solution [Available] |
The Following 2 Users Say Thank You to pramod 999 For This Useful Post: |
05-13-2016, 06:05 | #2 (permalink) | |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Quote:
Intex_Aqua_3G_V13_K_indian_SER Use Tool Ver. SP Flash Tool v3.1344.214 Now Open Sp Flash Tool Press Ctrl+Alt+V Now You Are In Advanced Mode In Tool Go Option Now Right Check On Physiaclly Formate Image Below Apply All Setting Image Below Now Go On Formate And Formate Your Handset After Formate SucessFully Flash Again Your Handset And Post Result Last edited by Deepesh Sharma; 02-17-2017 at 12:10. Reason: Image Correction | |
The Following 11 Users Say Thank You to Deepesh Sharma For This Useful Post: |
05-13-2016, 20:37 | #3 (permalink) | |
Member: 1397982 Status: Offline Thanks Meter: 44 | Quote:
help me sir my set dead | |
06-04-2016, 20:52 | #5 (permalink) |
Member: 1397982 Status: Offline Thanks Meter: 44 | Intex aqua 3G deag recovered solution When i format set give error bad block:0 error block:2 total block:2002 bad/erroe block ratio0. 100%) press ok to continue. Now set is totaly dead. I am try with miracle bix , volcano box, Gsm aladin, CS tool but not solved probleme. Thanks for reply sir. I really request to experts help me. Sorry for my bad english |
07-09-2016, 08:32 | #7 (permalink) | |
No Life Poster Join Date: Feb 2011 Location: LALGANJ RAEBARELI
Member: 1525102 Status: Offline Sonork: 100.1626123 Thanks Meter: 159 | Quote:
Me too done br but second step select manual Format | |
The Following 3 Users Say Thank You to durgesh4rbl For This Useful Post: |
12-02-2016, 14:46 | #11 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 912556 Status: Offline Thanks Meter: 25 | intex aqua 3g dead after flash set dead after flash and gives an error "brom error: s_da_update_bootloader_file_size_exceeds_bjavascri pt:void" . any one having solu to solve or guide me to solve pls help |
12-20-2016, 06:52 | #13 (permalink) | |
http://forum.gsmhosting.com/vbb/11814771-post2.html use search button before make any new thread | |
01-02-2017, 17:56 | #14 (permalink) |
Freak Poster Join Date: Jan 2014 Location: In Sanjary's Heart Age: 29
Member: 2114042 Status: Offline Sonork: 100.1652032 Thanks Meter: 46 | Intex Aqua Wonder Dead After Flash..plz GIVE Me Solution... when i try to flash this error show... BROM ERROR S DL PMT ERR NO SPACE 5069 |
