Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Intex
Old 05-12-2016, 20:06   #1 (permalink)
Member: 1397982
Thanks Meter: 44
Intex Aqua 3G Dead Recovered Solution [Available]
Intex aqua 3G dead in flashing. how to alive preloader. s/w v13k. my set is totaly dead. every version SP tool error. set comes to storage low probleme. please help. thanks
The Following 2 Users Say Thank You to pramod 999 For This Useful Post:
Old 05-13-2016, 06:05   #2 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Use This Ver. Flash File
Intex_Aqua_3G_V13_K_indian_SER
Use Tool Ver.
SP Flash Tool v3.1344.214
Now Open Sp Flash Tool
Press Ctrl+Alt+V Now You Are In Advanced Mode In Tool
Go Option Now Right Check On Physiaclly Formate Image Below
Apply All Setting Image Below
Now Go On Formate And Formate Your Handset
After Formate SucessFully Flash Again Your Handset And Post Result
The Following 11 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 05-13-2016, 20:37   #3 (permalink)
Member: 1397982
Thanks Meter: 44
Use Tool Ver.
Now Go On Formate And Formate Your HandsetThanks
Thanks sir for reply but probleme not solved. sp tool boom error
help me sir my set dead
Old 05-14-2016, 05:10   #4 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
error code post here
Old 06-04-2016, 20:52   #5 (permalink)
Member: 1397982
Thanks Meter: 44
Intex aqua 3G deag recovered solution
When i format set give error bad block:0 error block:2 total block:2002 bad/erroe block ratio0. 100%) press ok to continue. Now set is totaly dead. I am try with miracle bix , volcano box, Gsm aladin, CS tool but not solved probleme. Thanks for reply sir. I really request to experts help me. Sorry for my bad english
Old 07-08-2016, 18:59   #6 (permalink)
Member: 2008800
Thanks Meter: 8
Sir its work for me........... thanks
Old 07-09-2016, 08:32   #7 (permalink)
durgesh4rbl's Avatar
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 159
Me too done br but second step select manual Format
The Following 3 Users Say Thank You to durgesh4rbl For This Useful Post:
Old 08-14-2016, 11:36   #8 (permalink)
Member: 2499488
Sonork: Sriraghukavi
thank u working fine
Old 09-07-2016, 14:30   #9 (permalink)
Member: 835755
Sonork: jatinkavaiya
Sir I tried this trick phone flashed but phone is dead condition. Help plz. Any one Have read flash file upload plz
Old 09-08-2016, 19:25   #10 (permalink)
Hamid memon786's Avatar
Member: 2255989
Sonork: 1001675246
Thanks Meter: 47
After flash my phone is dead. Anybody have tasted file?
Old 12-02-2016, 14:46   #11 (permalink)
Member: 912556
Thanks Meter: 25
intex aqua 3g dead after flash
set dead after flash and gives an error "brom error: s_da_update_bootloader_file_size_exceeds_bjavascri pt:void" .
any one having solu to solve or guide me to solve pls help
Old 12-17-2016, 05:25   #12 (permalink)
Member: 2490308
Sonork: Mc.Manik
aqua 3g vol 08 dead solution
The Following User Says Thank You to milon gsmhnp For This Useful Post:
Old 12-20-2016, 06:52   #13 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Hello Try This Solution Step By Step ANd Post REsult
http://forum.gsmhosting.com/vbb/11814771-post2.html
use search button before make any new thread
Old 01-02-2017, 17:56   #14 (permalink)
Aamir8794's Avatar
Member: 2114042
Sonork: 100.1652032
Thanks Meter: 46
Intex Aqua Wonder Dead After Flash..plz GIVE Me Solution...
when i try to flash this error show...
BROM ERROR S DL PMT ERR NO SPACE 5069
Old 01-20-2017, 14:26   #15 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
try To Repartition Your Hand Set with ANy BOx
Or may be phone emmc dameg
Page generated in 0.23443 seconds with 8 queries
