Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Intex
Old 01-22-2017, 12:59   #16 (permalink)
Member: 1870893
Arrow intex aqua 3g dead not solution
intex aqua 3g dead not solution same error problem.
Old 01-22-2017, 14:06   #17 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 9,114
Hardware Problem
iF THIS TRICK NOT WORKED FOR YOY THEN ITS HARDWARE PROBLEM
Old 01-23-2017, 07:53   #18 (permalink)
Member: 2648918
whole formate after
same mobile ver select flash file bro in mirecle box
working thish method
Old 05-03-2017, 11:28   #19 (permalink)
Member: 1532776
Thanks Meter: 9
Originally Posted by Deepesh Sharma View Post
Use This Ver. Flash File
Intex_Aqua_3G_V13_K_indian_SER
Use Tool Ver.
SP Flash Tool v3.1344.214
Now Open Sp Flash Tool
Press Ctrl+Alt+V Now You Are In Advanced Mode In Tool
Go Option Now Right Check On Physiaclly Formate Image Below
Apply All Setting Image Below
Now Go On Formate And Formate Your Handset
After Formate SucessFully Flash Again Your Handset And Post Result
bro u save my life... love you...
Old 05-20-2017, 09:45   #20 (permalink)
Member: 2573943
Originally Posted by pramod 999 View Post
Thanks sir for reply but probleme not solved. sp tool boom error
help me sir my set dead
no solution same condition bro plz hepl me:confuse d:
Old 05-20-2017, 12:42   #21 (permalink)
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 9,114
may be its hardware fault try to fix by hardware
Old 06-11-2017, 14:40   #22 (permalink)
Member: 889598
Thanks Meter: 6
Originally Posted by deepesh sharma View Post
use this ver. Flash file
intex_aqua_3g_v13_k_indian_ser
use tool ver.
Sp flash tool v3.1344.214
now open sp flash tool
press ctrl+alt+v now you are in advanced mode in tool
go option now right check on physiaclly formate image below
apply all setting image below
now go on formate and formate your handset
after formate sucessfully flash again your handset and post result
thanks ur solution is very good .i was totally upset ,u save me
thanks again
Old 07-29-2017, 11:54   #23 (permalink)
Member: 1923501
Sonork: 100.1658355
Thanks Meter: 5
Thanks working
Originally Posted by durgesh4rbl View Post
Me too done br but second step select manual Format
Thanks Sir, Your trick is 100% working in my case. Thanks a lot.
Page generated in 0.26328 seconds with 7 queries
