05-11-2016, 01:52 | #17 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, Go To Settings In Flash Tool -> Flash Operations -> Click On "Erase All Flash" -> Ok. Then Flash It. After Flash Repair IMEI Etc. Post Result Please. |
The Following 12 Users Say Thank You to MyGSM World For This Useful Post: |
05-28-2016, 00:44 | #23 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, Use This Version IMEI Write Tool : WriteIMEI_R3.0.0001. Open Tool & Feel Both 15 Digits IMEI Then Click On "Write", Press & Holding Volume Down Key Insert USB Cable Then Insert Battery. Note : All Process Need To Do With In 30 Seconds, Otherwise IMEI Tool Stop & Need To Feel IMEI & Click On Write Again. Don't Release Volume Down Key Until You'll See "PASS!" & Green Color In IMEI Tool. Also Read Some Reference Threads From Beginning Please. http://forum.gsmhosting.com/vbb/f781...click-1672805/ http://forum.gsmhosting.com/vbb/f781...lable-1936252/ http://forum.gsmhosting.com/vbb/f781...r-pls-1936913/ http://forum.gsmhosting.com/vbb/f781...-tool-2080548/ |
The Following 4 Users Say Thank You to MyGSM World For This Useful Post: |
06-02-2016, 15:40 | #26 (permalink) | |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
If Your Cellphone Has Problem/Error Like Post No #18 Then Follow Solution Of Post No #19 Of Currently Thread. | |
06-18-2016, 22:03 | #28 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, How Did You "Erase" By Flash Tool? I Never Seen "Baseband Unknown" After "Erase" By Flash Tool. Yes, After "Erase" "Must" Need To Repair IMEI By IMEI Write Tool. Not Require NV File. |
