12-20-2014, 06:16 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | How to flash custom recovery on Q mobile and all MTK based phones Mostly user thinking custom roms installing not easy But its easy like 123 In this thread i shall post some method on custom recovery on any Q mobile and all other MTK based Android phones soon will be all Q mobile custom post Bro ATIF(sweet4hamza) |
The Following 2 Users Say Thank You to sweet4hamza For This Useful Post: |
12-20-2014, 06:59 | #2 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | How to flash cwm recovery without Root Its hard to find every Q mobile custom recovery but its no problem we have many methods to make your own custon recovery for All Q mobile and MTK based phones You can create / make your own CWM recovery to any of your Q mobile or any other MTK devices Well, with this guide that I will provide you, you will learn how to make your own and flash custom recovery to any of your Q mobile and other MediaTek devices. All you have to do is to carefully follow the steps so you can successfully do it well without problems. Let,s start How To make your own custom Recovery and flash it without rooting your MTK android device using MTK Droid Tools and SP Flash Tool. Supported chips All MTK based Qmobile android device or other mtk based Android phones with ext4 type of block (rooted or not rooted, it doesn't matter): MT6595, MT6592, MT6589, MT6582, MT6577, MT6575, MT6572, MT65xx required software mtk droid tools MtkDroidTools_v253 latest SP flasher https://forum.gsmhosting.com/vbb/****************************/?kmyvckwaafb8i8j Instructions: First, you have to prepare all necessary requirements and place it to the location where you are comfortable with. Download and install the MTK USB Drivers, wait for it to close itself because it includes 6 kinds of MTK USB drivers. Also, extract MTK Droid Tools to where you want it. You also need the scatter file for your device, you can easily make it yourself by just following the guide from the link and most importantly, make sure that you have your stock boot image for your device which we will use for creating the CWM recovery. If you don't have it, you have to follow the link above. [IMG]http://2.bp.********.com/-szqLTgWZ6a8/U3rbMoQqFwI/AAAAAAAAAf0/siE2FC-uC3g/s1600/req.JPG[/IMG] Make sure that USB Cable is disconnected or unplugged. Open MTK Droid Tools.exe (run as administrator) and go to root, backup, recovery tab. (if UBIFS warning appeared in the status message, this process will not work for you. Only ext4 supported.) [IMG]http://4.bp.********.com/-4Z6HobF2DUM/U3rccHxUuwI/AAAAAAAAAf8/CFEA5yPsOTo/s1600/mt.JPG[/IMG] From the root, backup, recovery tab, the radio button To choose the boot.img file was selected by default. All you have to do is click on Recovery and Boot button. [IMG]http://1.bp.********.com/-JDKuHMc-EZk/U3rdq9ICC6I/AAAAAAAAAgE/iVgy7FGwp-0/s1600/rb.JPG[/IMG] After clicking Recovery and Boot button, a new windows will appear asking where is your existing boot.img. In my case, I placed it on my Tools folder. Now, select and open the boot.img of your android devic [IMG]http://4.bp.********.com/-zwB_1NsIPyI/U3rfHKzq17I/AAAAAAAAAgQ/lYLwSFJS9Mg/s1600/rb1.JPG[/IMG] Wait a few seconds and a prompt asking To make CWM recovery automatically will appear. Click YES [IMG]http://2.bp.********.com/-h0jfxBPeqyg/U3rgBH5DStI/AAAAAAAAAgY/SDuUsn9K8b4/s1600/cwm.JPG[/IMG] Wait for the task to get completed, read the status messages on the right pane. If the task was successful, go to MTK Droid Tools -- recovery folder to check if the patching was done well. There will be two files, first is the patched boot image and the second is the recovery image which is the ClockworkMod (CWM) recovery. [IMG]http://3.bp.********.com/-rjdalqgmiaA/U3rjU_Bu7eI/AAAAAAAAAgs/fECzYu0naD8/s1600/rec.JPG[/IMG] Now that you have the CWM recovery already, we will proceed to flashing it through SP Flash Tool. Why? if you don't have root access, then use SP Flash Tool, otherwise if you are already rooted, use mobile uncle to update your recovery image. To flash CWM recovery without rooting your android device, open SP Flash Tool.exe (run as administrator). Click on Scatter-loading, then find and open the Scatter file of your android device. [IMG]http://1.bp.********.com/-KFbxTGY1c6g/U3rmOA7mI6I/AAAAAAAAAg4/xYLXLolV8gc/s1600/scat.JPG[/IMG] Now, the regions of your device will be loaded. You are only to flash the CWM recovery that you made earlier so click on Recovery. Navigate to MTK Droid Tools -- recovery folder and select the recovery image which is the CWM recovery that we have made earlier. [IMG]http://1.bp.********.com/-GrzZDUjGVXA/U3rodsMDdhI/AAAAAAAAAhE/goL128I8gXs/s1600/nw.JPG[/IMG] Make sure that RECOVERY is the only one that checked. Now we will start flashing the recovery. Also, make sure that the USB Cable is unplugged from your device. Now you nee to turn off your android device (shutdown or remove the battery). When your device was already powered off, from SP Flash Tool click Download , select YES then immediately connect your device to your computer via USB Cable. [IMG]http://1.bp.********.com/-WDDJ9FmB9ho/U3ruEXdkplI/AAAAAAAAAhY/tDV80ms0gTM/s1600/dl.JPG[/IMG] Your device must be detected even it is turned off since you have installed the MTK USB Drivers from the requirements. You'll notice that your android device was detected after you'll see the blue and red color loading on SP Flash Tool's status. Wait for the download to be done. If done, it will look like the image below: [IMG]http://4.bp.********.com/-g5Iy8_qyVRU/U3rwPWi41nI/AAAAAAAAAhk/ynlTU_UJ2Tg/s1600/ok.JPG[/IMG] To verify if you have successfully flashed CWM Recovery on your unrooted android device, unplug or disconnect the USB Cable from your device and try to reboot to recovery (use the combo keys or rebooter app). Congratulations!! You have successfully flashed ClockworkMod recovery on your unrooted android device. Now just put costum rom on your mc card and update it by recovery method |
The Following 6 Users Say Thank You to sweet4hamza For This Useful Post: |
12-22-2014, 07:19 | #3 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | How To Flash Stock/Custom Recovery Using SP Flash Tool on Qmobile How To Flash Stock/Custom Recovery Using SP Flash Tool on Qmobile Only follow the steps provided. Applying the procedure means you are fully responsible for the possible outcome of your device. If you are confused, read the steps again, if you hesitate, do enough research Things you need: Qmobile or other MTK-based device: MT6595, MT6592, MT6589, MT6582, MT6577, MT6575, MT6572, MT6573 Scatter File for your MTK device boot and recovery file SP Flash Tool and all drivers must installed Preparations: Download and install the Drivers (click the Install bat file and wait for it to finish the installation so don't close it). Create your own scatter file if you don't have one, it differs from each MTK device. Download and extract SP Flash Tool. Finally the recovery (stock or custom/CWM/TWRP) which is made for your device (make sure it is named as recovery only not cwm_recovery, etc.), don't flash recovery that is not made for your device. [IMG]http://2.bp.********.com/--PV5HLbOJ_4/U5RiFA9iZrI/AAAAAAAAA24/wxzUQM5zvH4/s1600/need.JPG[/IMG] Instructions: [IMG]http://1.bp.********.com/-TJDf8VPk5u8/U5RmXQ0fafI/AAAAAAAAA3I/n1-E5OOE4Vg/s1600/st1.JPG[/IMG] Open SP Flash Tools and click Scatter Loading, now select the scatter file of your device. [IMG]Open SP Flash Tools and click Scatter Loading, now select the scatter file of your device.[/IMG] Make sure all boxes are NOT checked, if there's a check, remove it by clicking the check. [IMG]http://1.bp.********.com/-L6v68QB0Dv8/U5RmYPq4_QI/AAAAAAAAA3U/JVZnPfNSWEg/s1600/st3.JPG[/IMG] Now, click RECOVERY from the list. A new window will appear, find the recovery image that you want to flash or install and click Open. [IMG]http://4.bp.********.com/-fA2CEfsvpGw/U5RmcWnmi2I/AAAAAAAAA3c/saQco1sgZ1g/s1600/st4.JPG[/IMG] It will now look like the image above. The RECOVERY is the ONLY one checked on the list and you can see the location of the recovery image that you are going to flash [IMG]http://1.bp.********.com/-qfEpi8CyBjE/U5RpKFppZhI/AAAAAAAAA34/sApyHbRalPs/s1600/st5.JPG[/IMG] TURN OFF your android phone. When it is already off, click the Download button on the SP Flash Tool, then click Yes. After that, connect your switched-OFF phone to your computer using USB Cable. [IMG]http://1.bp.********.com/-al4QbUMZQ6U/U5RpC92p9tI/AAAAAAAAA3w/3NlBg5VbvmA/s1600/ok.JPG[/IMG] The tool will detect your phone and flash the recovery, if your computer can't detect your phone, re-install the Drivers that I have provided. Wait until a prompt with green circle will appear, that means the flashing is done successfully Congrats! You are done flashing the stock/custom recovery for your Qmobile phone. |
The Following 3 Users Say Thank You to sweet4hamza For This Useful Post: |
12-27-2014, 12:37 | #4 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | FLASH recovery on Q mobile without sp flasher FLASH recovery on Q mobile or other MTK based phone without sp flasher First root your phone Install mobile uncle tool.apk Put recovery file in your sd card Open mobile uncle tool Select flash recovery then select the sustom recovery Then reboot your done with flashing recovery here is mobile uncle tool.apk https://forum.gsmhosting.com/vbb/****************************/?slcgu6gxbrndamq |
The Following 12 Users Say Thank You to sweet4hamza For This Useful Post: |
