05-01-2014, 06:00 | #19 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected Bro..... Follow This Procedure.... Press (Volume down -) and Power Button you will enter in Fast Boot Mode or Screen Shows Only Fast Boot mode now open Volcano Box Go into the Android Tab and open FASTBOOT Tab check the Is Fastboot then right down Wipe Data all the user data will be Vanasihed or delete but your problem will be solved i tested many times Post results after doing all this procedure.. B/R Sheraz.... |
07-24-2014, 11:02 | #23 (permalink) |
Freak Poster Join Date: Sep 2013 Location: PaKiStAn & KSA
Member: 2023768 Status: Offline Sonork: 100.1661054 Thanks Meter: 76 | if you do,nt have volcano box you can use andriod multi tool for reset your any andriod device in fastboot mode in adb mode hare is link for andriod multi tool Android Multi Tools v1.02b - Download - 4shared |
09-17-2016, 15:08 | #24 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1140913 Status: Offline Thanks Meter: 0 | you dont need to go in fast boot mode. 1. just install phone drivers 2. run android multi tool. 3. start the phone 4. connect the phone with usb cable to pc 5. press 1 to check whether the device is connected or not. 6. press 4 to reset gmail phone will restart and you are done cheers |
