04-10-2016, 17:43 | #1 (permalink) |
Banned Join Date: Apr 2008
Member: 744438 Status: Offline Sonork: 100.1640287 Thanks Meter: 279 | Qmobile A290 Dead After Flash Recovery Successfully By FlashRepair1 By using this method you can recover Mostly MTK Devices Specially Q Mobile Open your device and Connect Kcolo to Ground and Flash Device it'll connect to pc and accept flash Hop you can recover your phone successfully |
The Following User Says Thank You to marhabamobiles For This Useful Post: |
05-23-2016, 14:19 | #2 (permalink) |
No Life Poster Join Date: Jun 2013 Location: PK Lahore Panjab
Member: 1965559 Status: Offline Sonork: 100.1622928 Thanks Meter: 1,834 | You dont need to open the phone, connect it without battery. Or combine press the Volume-up and Volume-down button and then connect it, it will be connected. It's the most easiest method, Use 'Boot Cable' or 'Boot Jig'. |
05-23-2016, 22:15 | #3 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | when boot dead You cant Flash without KOLO Soldering thats why those point are on board. just flash preloader file then disconect KOLO and flash over USB the whole Firmware ( Fast Flashing) on KOLO ( slow Flashing ) . there are 3 different firmware for Qmobile A290 . be carefull |
06-04-2016, 10:44 | #4 (permalink) |
Freak Poster Join Date: May 2016 Location: pakistan
Member: 2577320 Status: Offline Sonork: 100.1676251 Thanks Meter: 21 | i have qmobile a290 i flash 3g file simple file all firmware flash but set dead any one have tested file ??????????????????????????????? |
08-02-2016, 06:27 | #5 (permalink) |
Freak Poster Join Date: Feb 2010 Location: karachi pakistan
Member: 1237819 Status: Offline Sonork: [email protected] Thanks Meter: 148 | mr bhati 'Boot Cable' or 'Boot Jig'. not work im trid but fail but koclo done 100% |
