12-27-2015, 12:15 | #3 (permalink) |
Freak Poster Join Date: Oct 2015 Location: eArTh
Member: 2470191 Status: Offline Sonork: 100.1652036 Thanks Meter: 308 | Try This Methed Qmobile T400 Hard Reset 1 Turn off your cell phone. 2 Press and hold Volume Up button then press power button 3 factory mode appear on T400 screen 4 Select research option then Select recovery 5 now wipe factory data and cache HOPE UR PROBLM WILL SOLVE WITH THIS |
11-09-2016, 09:04 | #12 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan Age: 35
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | from phone dial Dial *#*#83781#*#* you will see the engineering mode the first option you will see is auto answer call. if its enabled then disable it or if its already disabled then enable it once and disable it. the problem will be fixed. |
The Following 13 Users Say Thank You to androidlabs For This Useful Post: |
04-05-2017, 07:53 | #14 (permalink) | |
Freak Poster Join Date: Oct 2015 Location: Pakistan Age: 36
Member: 2477331 Status: Offline Sonork: 100.1676088 Thanks Meter: 29 | Quote:
thanx brother your method is working.. | |
The Following User Says Thank You to Bajwa786 For This Useful Post: |
