Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Q-Mobile
Old 02-13-2016, 17:36   #1 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
Wrong flashed set problem
Now a days i recieve many MTK sets which dead because of wrong firmware.some give error on SPtool (s_dl_pmt_err_no_space (5069).means problem in partition as far as i know because i am not expert.I have Tested rom,s for Qmobile but that also not cure fot that.My question is if any method to recover that dead phones because all alived before flashed.If method not exist I request to Infinity team plz make something about it.
Here is some log from Phone.
Identify
Operation : Check / Read Info [ v1.40 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v5.1540.01.01
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048600A3588A1191
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048600A3588A1191
[eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Info read not done :( Erased phone or unsupported FlashIc?
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
Erase
Operation : Flash Erase [ v1.40 ]
User accepted Flash Erase operation!
Wait for phone...
Phone found! [ 10 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Keep Preloader alive
Flash erase done
Done!
Elapsed: 00:00:21
Flash
Operation : Flash [ v1.40 ]
======= Flash
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
DRAM Init Ok , 0x20000000
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4031a , Storage : EMMC
Setting : AFF verify :  Enabled
Setting : HW verify :  Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3715 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x0000000081C40000
Flash Pre-Erase Done, time used : 00:00:22
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4031a.bin
Preloader Init Failed! Looks like HW error or incompatible image
ErrCode :
Operation Failed
Elapsed: 00:00:52
Old 02-18-2016, 06:35   #2 (permalink)
bombinson's Avatar
Member: 1973579
Thanks Meter: 30
Post This in infinity box section for support bro.
Old 02-18-2016, 07:36   #3 (permalink)
Akshayhackman's Avatar
Member: 2524325
Sonork: 100.1671897
Thanks Meter: 179
use Volcano Merapi
Identify
Wait for phone...
Phone found! [ 10 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:09
Erase
Wait for phone...
Phone found! [ 10 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Flash erase done
Done!
Elapsed: 00:00:21
Flash
======= Flash
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Switching to HSUSB
HSUSB Init Ok
ErrCode :
Operation Failed
Elapsed: 00:00:52
use Volcano Merapi tool and solve your problem
Page generated in 0.20337 seconds with 8 queries
