Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > IMEI Source® | Professional Unlocking Server
IMEI Source® | Professional Unlocking Server The Wholesale Unlocking Store
Old 12-07-2016, 19:56   #1 (permalink)
nerobdms™'s Avatar
Member: 1179761
Sonork: 100.1602000
Thanks Meter: 1,829
Post Z3X Samsung Pro Activation / Z3X Samsung Activation / Z3X LG Activation - 24/7
The Following User Says Thank You to nerobdms™ For This Useful Post:
Old 12-07-2016, 21:30   #2 (permalink)
IMEI Source's Avatar
Member: 2185503
Sonork: 100.1602000
Thanks Meter: 332
Z3X-BOX Samsung Update. Samsung Tool PRO 27.4. Patch certG930x/G935x, New reset FRP.
Samsung Tool PRO 27.4 Released. Patch cert new FW G930x/G935x, New method reset FRP in flash mode)
Some hot solution again added and some fix, we hope all z3x pro users will be happy.
Added:
- support patch CERT on new FW G930x/G935x
- support SM-G600F (Unlock(root) Direct (not root) Read codes (world first), Direct (no root) Read Cert (world first), Write CERT, Repair IMEI, Patch CERT (repair network) - (world first))
- support SM-G610L (Unlock(root) Direct (not root) Read codes (world first), Direct (no root) Read Cert (world first), Write CERT, Repair IMEI, Patch CERT (repair network) - (world first))
- support SM-G610S (Unlock(root) Direct (not root) Read codes (world first), Direct (no root) Read Cert (world first), Write CERT, Repair IMEI, Patch CERT (repair network) - (world first))
- Addition support SM-A9000 (New method reset FRP in flash mode)
- Addition support SM-A9100 (New method reset FRP in flash mode)
- Addition support SM-A910F (New method reset FRP in flash mode)
- Addition support SM-С5000 (New method reset FRP in flash mode)
- Addition support SM-С7000 (New method reset FRP in flash mode)
- Addition support SM-G360T (New method reset FRP in flash mode)
- Addition support SM-G360T1 (New method reset FRP in flash mode)
- Addition support SM-G530P (New method reset FRP in flash mode)
- Addition support SM-G530T (New method reset FRP in flash mode)
- Addition support SM-G530W (New method reset FRP in flash mode)
- Addition support SM-G5500 (New method reset FRP in flash mode)
- Addition support SM-G550F (New method reset FRP in flash mode)
- Addition support SM-G550FY (New method reset FRP in flash mode)
- Addition support SM-G550T (New method reset FRP in flash mode)
- Addition support SM-G550T1 (New method reset FRP in flash mode)
- Addition support SM-G550T2 (New method reset FRP in flash mode)
- Addition support SM-G9200 (New method reset FRP in flash mode)
- Addition support SM-G9208 (New method reset FRP in flash mode)
- Addition support SM-G9209 (New method reset FRP in flash mode)
- Addition support SM-G920A (New method reset FRP in flash mode)
- Addition support SM-G920AZ (New method reset FRP in flash mode)
- Addition support SM-G920D (New method reset FRP in flash mode)
- Addition support SM-G920F (New method reset FRP in flash mode)
- Addition support SM-G920FD (New method reset FRP in flash mode)
- Addition support SM-G920FQ (New method reset FRP in flash mode)
- Addition support SM-G920I (New method reset FRP in flash mode)
- Addition support SM-G920K (New method reset FRP in flash mode)
- Addition support SM-G920L (New method reset FRP in flash mode)
- Addition support SM-G920R4 (New method reset FRP in flash mode)
- Addition support SM-G920P (New method reset FRP in flash mode)
- Addition support SM-G920S (New method reset FRP in flash mode)
- Addition support SM-G920T (New method reset FRP in flash mode)
- Addition support SM-G920T1 (New method reset FRP in flash mode)
- Addition support SM-G920V (New method reset FRP in flash mode)
- Addition support SM-G920W8 (New method reset FRP in flash mode)
- Addition support SM-G9250 (New method reset FRP in flash mode)
- Addition support SM-G925A (New method reset FRP in flash mode)
- Addition support SM-G925D (New method reset FRP in flash mode)
- Addition support SM-G925F (New method reset FRP in flash mode)
- Addition support SM-G925FQ (New method reset FRP in flash mode)
- Addition support SM-G925I (New method reset FRP in flash mode)
- Addition support SM-G925J (New method reset FRP in flash mode)
- Addition support SM-G925K (New method reset FRP in flash mode)
- Addition support SM-G925L (New method reset FRP in flash mode)
- Addition support SM-G925P (New method reset FRP in flash mode)
- Addition support SM-G925R4 (New method reset FRP in flash mode)
- Addition support SM-G925S (New method reset FRP in flash mode)
- Addition support SM-G925T (New method reset FRP in flash mode)
- Addition support SM-G925V (New method reset FRP in flash mode)
- Addition support SM-G925W8 (New method reset FRP in flash mode)
- Addition support SM-G925Z (New method reset FRP in flash mode)
- Addition support SM-G9280 (New method reset FRP in flash mode)
- Addition support SM-G9287 (New method reset FRP in flash mode)
- Addition support SM-G9287C (New method reset FRP in flash mode)
- Addition support SM-G928A (New method reset FRP in flash mode)
- Addition support SM-G928C (New method reset FRP in flash mode)
- Addition support SM-G928F (New method reset FRP in flash mode)
- Addition support SM-G928G (New method reset FRP in flash mode)
- Addition support SM-G928I (New method reset FRP in flash mode)
- Addition support SM-G928K (New method reset FRP in flash mode)
- Addition support SM-G928L (New method reset FRP in flash mode)
- Addition support SM-G928N0 (New method reset FRP in flash mode)
- Addition support SM-G928P (New method reset FRP in flash mode)
- Addition support SM-G928S (New method reset FRP in flash mode)
- Addition support SM-G928T (New method reset FRP in flash mode)
- Addition support SM-G928W8 (New method reset FRP in flash mode)
- Addition support SM-J320N0 (New method reset FRP in flash mode)
- Addition support SM-J320P (New method reset FRP in flash mode)
- Addition support SM-J320R4 (New method reset FRP in flash mode)
- Addition support SM-J320Y (New method reset FRP in flash mode)
- Addition support SM-J320YZ (New method reset FRP in flash mode)
- Addition support SM-J320ZN (New method reset FRP in flash mode)
- Addition support SM-J5007 (New method reset FRP in flash mode)
- Addition support SM-J500F (New method reset FRP in flash mode)
- Addition support SM-J500FN (New method reset FRP in flash mode)
- Addition support SM-J500G (New method reset FRP in flash mode)
- Addition support SM-J500H (New method reset FRP in flash mode)
- Addition support SM-J500M (New method reset FRP in flash mode)
- Addition support SM-J500N0 (New method reset FRP in flash mode)
- Addition support SM-J500Y (New method reset FRP in flash mode)
- Addition support SM-J510F (New method reset FRP in flash mode)
- Addition support SM-J510FN (New method reset FRP in flash mode)
- Addition support SM-J510GN (New method reset FRP in flash mode)
- Addition support SM-J510H (New method reset FRP in flash mode)
- Addition support SM-J510K (New method reset FRP in flash mode)
- Addition support SM-J510L (New method reset FRP in flash mode)
- Addition support SM-J510MN (New method reset FRP in flash mode)
- Addition support SM-J510S (New method reset FRP in flash mode)
- Addition support SM-J510UN (New method reset FRP in flash mode)
- Addition support SM-J7109 (New method reset FRP in flash mode)
- Addition support SM-P350 (New method reset FRP in flash mode)
- Addition support SM-P355 (New method reset FRP in flash mode)
- Addition support SM-P355M (New method reset FRP in flash mode)
- Addition support SM-P550 (New method reset FRP in flash mode)
- Addition support SM-P555 (New method reset FRP in flash mode)
- Addition support SM-P555C (New method reset FRP in flash mode)
- Addition support SM-P555K (New method reset FRP in flash mode)
- Addition support SM-P555L (New method reset FRP in flash mode)
- Addition support SM-P555M (New method reset FRP in flash mode)
- Addition support SM-P555S (New method reset FRP in flash mode)
- Addition support SM-P555Y (New method reset FRP in flash mode)
- Addition support SM-T355 (New method reset FRP in flash mode)
- Addition support SM-T355C (New method reset FRP in flash mode)
- Addition support SM-T355Y (New method reset FRP in flash mode)
- Addition support SM-T357W (New method reset FRP in flash mode)
- Addition support SM-T536 (New method reset FRP in flash mode)
- Addition support SM-T550 (New method reset FRP in flash mode)
- Addition support SM-T555 (New method reset FRP in flash mode)
- Addition support SM-T555C (New method reset FRP in flash mode)
- Addition support SM-T713 (New method reset FRP in flash mode)
- Addition support SM-T719 (New method reset FRP in flash mode)
- Addition support SM-T719C (New method reset FRP in flash mode)
- Addition support SM-T719Y (New method reset FRP in flash mode)
- Addition support SM-T813 (New method reset FRP in flash mode)
- Addition support SM-T819 (New method reset FRP in flash mode)
- Addition support SM-T819C (New method reset FRP in flash mode)
- Addition support SM-T819Y (New method reset FRP in flash mode)
Fixed:
- J120W read codes/cert
- Read codes/CERT/unlock on Shannon305 (G570F...)
- check CERT on Shannon315 (J710F ..)
- "Install now" function ("update available" window)
Buy z3x Activation: z3x All Activations
Old 12-10-2016, 17:45   #3 (permalink)
Member: 2185503
Sonork: 100.1602000
Thanks Meter: 332
Z3X-BOX Samsung Update. Samsung Tool Pro 27.5. Released. Exclusive MTK based samsung
Samsung Tool PRO 27.5. Exclusive 1st world
Today we add new and exclusive solutions - MTK based samsung phones support:
- support SM-G532F (Flashing, Backup/Restore CERT, Unlock, Read codes, Reser FRP in flash mode (TEST), reboot download/recovery) - first in the world
- support SM-G532G (Flashing, Backup/Restore CERT, Unlock, Read codes, Reser FRP in flash mode (TEST), reboot download/recovery) - first in the world
- support SM-G532M (Flashing, Backup/Restore CERT, Unlock, Read codes, Reser FRP in flash mode (TEST), reboot download/recovery) - first in the world
Note: cert contains HWID based sign, so cannot be written to another phone
Old 12-11-2016, 14:05   #4 (permalink)
Member: 2654147
Sonork: 070.2600
nice upduta z3x team, surely it will help us z3x fanatic.
Page generated in 0.47871 seconds with 7 queries
