Lenovo General Lenovo phones discussion, firmwares, solution, help |
12-10-2015, 11:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Backup and restore EFS for Lenovo devices based on Qualcomm . how using the program QFIL back up EFS on a PC, as well as the process of restoring a backup EFS in a Lenovo device based Qualcomm. 1st download installed software package QPST Here. QPST_2.7.422 - Download - 4shared - Andy Suwito After install packge. proceed directly to the process of pair your device with a PC: 1. After connecting the device to a PC via USB-cable, opening a "dialer" on the device dials * # * # 8899 # * # * and confirm by clicking "OK" In Device Manager, the PC you should see the following picture (if the correct set of drivers) Like this image. 2. Go to the folder that was produced installation software package QPST, and run QFIL.exe Screen make sure that the program has detected the device mode Lenovo HS-USB Diagnostics Screen. 3. In the Run window, go to the tab "Tools" and click on the "QCN Backup Restore" 4. Go to the most important point: 4.1. Backup EFS - in the window that opens, click on the button "Backup QCN" and wait for the end of the backup process. Default backup EFS (file 00000000.qcn) will be saved in the folder C: \ temp \, a place to save and name of the backup is better not to change. Log successfully created backup. Process Index: 0 Start Download QCN COM Port number: 7 Checking if phone is connected ... IsPhoneConnected: Passed. Phone is connected Sent SPC code to the phone successfully Downloading QCN file: C: \ temp \ 00000000.qcn Done downloading the qcn file: C: \ temp \ 00000000.qcn Finish Backup QCN 4.2. EFS recovery from a backup - in the window that opens, click on the button "Browse", specify the path to the file 00000000.qcn and click "Open." Then click on the button "Restore QCN" and wait for the restore process. Log successfully restore backup Process Index: 0 Start Restore QCN COM Port number: 7 Uploading QCN file: C: \ temp \ 00000000.qcn Checking if phone is connected ... Done uploading the QCN file: C: \ temp \ 00000000.qcn Finish Restore QCN . Thanks for understanding. |
The Following 7 Users Say Thank You to Dooha_Bd For This Useful Post: |
05-18-2017, 16:23 | #5 (permalink) |
Major Poster Join Date: Oct 2013
Member: 2038521 Status: Offline Thanks Meter: 3 | lenovo a6010 imei repair done ... i could change imei by using another qcn and without qcn just using Qualcomm Imei W&R tool. i have changed the imei 10 times . every thing is ok,has imei and basbend ..but still no service on lenovo a6010 |
