Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 04-18-2019, 21:15   #1 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 88
I need to remove FRP Lenovo Tab E10
Hello
I am involved trying to remove an FRP to Lenovo Tab E10 and I could not give solution.
I Tried with several boxes, I can not remove the account.
Can you please give me some solution for this?
Thank you
Old 04-18-2019, 21:18   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,772
Maybe,
as soon as you post EXACT and FULL model of your device.
You can also enter recovery and see what is written inside,
or post some picture of it.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 04-18-2019, 22:12   #3 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 88
Sorry for not giving more details
This is what it shows in fastboot mode.
It is a Lenovo Tab E10, MSM8909 processor.
Thanks
mfeliu07
Old 04-19-2019, 00:23   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,772
It should be Lenovo TB-X103F ,
now, while in that boot menu, use volume up and down keys,
and enter RECOVERY ... there is exactly written which software version/model
is currently inside that specific device.
Post those details too.
(or use different key combination to enter recovery)
b.r.
Alex
__________________
Old 04-19-2019, 13:59   #5 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 88
b.r.
Alex
the recovery does not show anything that can help, I think
Thanks
Old 04-19-2019, 20:51   #6 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,772
Okay,
but without knowing EXACT model, I am not able to help you.
Try to find exact model number and post here.
b.r.
Alex
__________________
Old 04-23-2019, 20:06   #7 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 88
Hello
I think I could find the model, it seems to be TB-X104F
Thanks
Old 04-23-2019, 20:54   #8 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,772
Hello
Thanks
first try the easy way :
- boot into fastboot mode (Power off device - press on/off + Volume UP - device restarts to fastboot mode)
- install minimal ADB, open command prompt
- issue command: fastboot oem unlock-go
- check device screen and command output
- if needed, confirm bootloader unlock on device
- after full power-on of device, shut it down again
- repeat entering fastboot mode on device
- issue fastboot command: fastboot erase config
- check output if okay
- if okay, issue fastboot command: fastboot reboot
frp should be gone.
b.r.
Alex
__________________
Old 04-24-2019, 17:40   #9 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 88
Hello
I cant, error remote: oem unlock is not allowed
Old 04-24-2019, 21:10   #10 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,772
Hello
There is still possibility, but is dangerous
and I would not recommend doing anything else via PC.
Reason: I don't have full rom for your device, and cant make frp remove package.
If you manage to get full flashable rom for same exact version of your device
(and same hardware code - which should be for your device : code 10),
you can forward that package, and I can make FRP remover.
(But is still dangerous if you don't know what are you doing).
p.s. If you have some BOX with QUALCOMM module, it will be easy task.
write PM if so, I will send you needed loader.
b.r.
Alex
__________________
Page generated in 0.18060 seconds with 8 queries
