K8 NOTE imei rebuild error-help me baseband ok-imei blank MauiMETA_v9.1635.23 error as below https://image.ibb.co/nbP0vp/k8.png help me |
Hi, Check your ''Android_Gadget_CDC_driver'' installed properly in your PC or Read the sticky thread carefully & watch the video tutorial, hopefully you will be done. http://forum.gsmhosting.com/vbb/9639135-post1.html |
... and if still the same, backup nvdata partition, then erase it, then repeat repair procedure. b.r. Alex |
Hi, first of all you need to enable usb debugging as well as OEM unlock option and let the drivers installed after that enable ADB option in Maui meta tool then connect your phone and repair the imei |
