Lenovo General Lenovo phones discussion, firmwares, solution, help |
02-08-2017, 20:13 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | Lenovo k5 Note A7020a48 ( k52t38 ) ROM if any buddy have this file kindly share here thanks advance |
The Following User Says Thank You to nadim electro For This Useful Post: |
02-09-2017, 00:09 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
Available ROM's : A7020a48_S318_161128_ROW - Аndroid 6.0, VIBE UI 3.6, Euro/ROW A7020a48_S312_160926_ROW - Аndroid 6.0, VIBE UI 3.6, Euro/ROW A7020a48_S259_1600721_ROW - Аndroid 6.0, VIBE UI 3.6, Euro/ROW A7020a48_LL_S125_160419_ROW - Android 5.1, VIBE UI 3.х, Euro/ROW archive pass : lenovo-forums.ru b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 27 Users Say Thank You to Brka For This Useful Post: |
02-09-2017, 07:14 | #3 (permalink) |
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | thanks for your reply sir but i am sure my model is lenovo k52t38 i see model in software and also in back of the cover well i am downloading the file mybe rom work when software done will informed you ***** EDIT : during flashing error and set stuck at logo tool dl imge failed. Last edited by Brka; 02-23-2017 at 22:02. Reason: merged posts |
The Following 3 Users Say Thank You to nadim electro For This Useful Post: |
02-10-2017, 07:14 | #4 (permalink) | |
p.s. why did you needed the rom ? what was the initial problem with phone ? b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
02-12-2017, 15:49 | #6 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | lenovo k5 note k52t38 hello sir salaaam,,,,,,,,sir i have lenovo k5 note k52t38 ,,,,,,, everythingis perfact but 3g not working ,,,,,,,, i have about 5 phones all have sam problem any help sir ????????? also try flash but still problem ,,,,,,,, |
02-12-2017, 20:04 | #7 (permalink) | |
check which one you have, they have different basebands, Flash according to model you have. p.s. A7020a48 (K52e78) is model, without Fingerprint Scanner. p.s.2 A7020a40 is model WITH Fingerprint Scanner. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 03-23-2017 at 22:45. Reason: added download links, updated info | |
The Following 7 Users Say Thank You to Brka For This Useful Post: |
02-13-2017, 07:03 | #8 (permalink) | |
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | Quote:
i flash with these both firwmare A7020a48 (K52e78), and A7020a40 ROW. but still no network in wcdma,,,,,,,, my Place is Pakistan | |
02-14-2017, 20:39 | #10 (permalink) | |
than those which are in your phone. Of course, if so - nothing can be done. b.r. Alex
02-22-2017, 06:55 | #11 (permalink) | |
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | Quote:
after flash set working fine but bb unkwn any solution? | |
02-22-2017, 23:57 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Incorrect flash file, or bad NVM area, or ... hardware fault. br. Alex
03-23-2017, 16:29 | #14 (permalink) |
Freak Poster Join Date: Dec 2011 Location: rajasthan,india
Member: 1705399 Status: Offline Thanks Meter: 81 | lenovo k52_a48 firmware needed dear brka sir please help me i need lenovo k52_a48 firmware Brand : Lenovo ProdName : k52_a48 ProdModel : Lenovo A7020a48 Device : A7020a48 AndroidVer: 6.0 MTK CPU : MT6755 MTK PRJ : alps-mp-m0.mp7-V2.3_lenovo6755.66c.m_P164 Display ID: A7020a48_S318_161128_ROW please sir need working firmware badly so please help me |
03-23-2017, 22:41 | #15 (permalink) | |
You can "convert" Chinese K52e78 to ROW version with THIS rom. However, BEFORE FLASHING IT, BE SURE TO MAKE BACKUP of nvram and nvdata partitions ! In SPFT - "Memory read" option, add, select save location and file name (nvram.bin) - start address : 0xd780000 , length : 0x500000 again, for nvdata - add, select save location and file name (nvdata.bin) - start address : 0x4bc8000 , length : 0x2000000 ONLY after you made mentioned backup - flash posted rom file. After flashing, IMEI/WiFi/BT/Serial will be gone. To restore it - use again SPFT - press CTRL + ALT + V , Window, Memory write, and select nvram.bin, input same address as for read : 0xd780000 , press write, wait for finish, repeat procedure with nvdata.bin - address : 0x4bc8000 After all done, enter phone recovery menu, make Wipe Data / Factory reset, then Reboot. All should be working normal. test, and post results, also post your copy of nvram + nvdata, may be usefull to others. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 08-01-2017 at 22:03. Reason: added info | |
