Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 09-05-2015, 06:41   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
lenovo a6000 unfortunately has stopped android fix (Solved)
unfortunately has stopped android fix , itried format and reset everything but same after so i need flash file
Old 09-05-2015, 07:00   #2 (permalink)
saifjaan009's Avatar
Member: 2340225
Sonork: 100.1662389
Thanks Meter: 367
Thumbs up Lenovo A6000 Firmware
Download Here lenovo a6000 firmware
How To Flash
Extract the rar and in that folder go to backup and then inside the another folder edit the nandroid.md5 file with notepad++ and remove the 2 lines data tar and data tar a completely with some numbers...
And place clockworkmod folder in ur internal storage
Boot to recovery ..by pressing volume up and down and power at the same time
Select restore by navigating up and down using volume buttons
it should do the trick..
__________________
Please Don't Break Rules
BR;
..:: Saif Ur Rahman ::..
The Following User Says Thank You to saifjaan009 For This Useful Post:
Old 09-05-2015, 07:30   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
any easy procedure? your procedure not clear
Old 09-05-2015, 07:48   #4 (permalink)
Member: 2340225
Sonork: 100.1662389
Thanks Meter: 367
Flashing Lenovo A6000.
Extract stock rom and save in clockworkmod folder on SDCard
Enter recovery mode CWM and select backup and restore
Select restore and confirm it by pressing OK
Flashing ROM process will run, just wait a moment
Finall step is reboot your Lenovo A6000
Finish
__________________
BR;
Old 09-05-2015, 08:06   #5 (permalink)
Member: 2340225
Sonork: 100.1662389
Thanks Meter: 367
If U Not Understand So Watch This Full Video
__________________
BR;
Old 09-05-2015, 11:16   #6 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
__________________
BR;
flash done as your manul
thanks a lot perfect job thanks again
Page generated in 0.14161 seconds with 8 queries
