Lenovo General Lenovo phones discussion, firmwares, solution, help |
05-21-2017, 16:54 | #1 (permalink) |
Major Poster Join Date: Oct 2013
Member: 2038521 Status: Offline Thanks Meter: 3 | Lenovo a6010 imei repair/qualcomm imei repair/lenovo/mi/q mobile any qualcomm imei 1.YOU NEED INSTALL QUALCOMM DRIVERS FIRST 2.And root your device using kingo root or any other way that you like most. 3.Make sure you have USB debugging enabled in Settings > Development on your device for imei repairing you need to enable diag port .without diag enabling qualcomm imei repair impossible . so lets enable diag port now i will tell you how to enable qualcomm diag port enable. - Install ADB on attachment - Open ADB folder press SHIFT button and the right-click mouse button and choose “Open command prompt here” and write these commands : # adb shell # su # setprop sys.usb.config diag,adb okay friends ..now you can see a new hardware drive installing on the pc.. As "Qualcomm HS-USB Diag com" now you can write imei using any qualcomm imei repair tool........... Last edited by Brka; 05-22-2017 at 23:11. Reason: removed FB crap |
02-15-2018, 23:29 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | You don't need adb, only Qualcomm drivers. That guy just copy-pasted some blog article, without understanding how and why. To enable diag interface, on powered off phone: hold volume UP + power on phone should go into test menu and diag port should appear. All necessary stuff (ADB/Qcom Drivers, qcn file, ImeiWriter, etc) - HERE b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 02-15-2018 at 23:50. Reason: added links |
The Following 6 Users Say Thank You to Brka For This Useful Post: |
