Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 01-20-2016, 18:48   #1 (permalink)
Member: 638919
Thanks Meter: 17
lenovo A816 dead after flash
device become cannot power on after flashing with Lenovo_A816_S017_150527 by miflash.
now usb driver become qshusb_bluk........pls give me some guide how to flash back to power on
Old 01-20-2016, 19:21   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,985
Fortunatly, it CAN be unbricked.
Full Instructions how to use QFIL (from QPST) (translated) - HERE
**** EDIT: Tested Multi-Language ROM for phones from Europe (tested on phone from serbia):
A816_A_0017_140928 - VIBEUI_V2.0_1439_ST Android 4.4.4
Used xml file - update_wipe.xml
And another ROM for Chinese A816 - HERE
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 3 Users Say Thank You to Brka For This Useful Post:
Old 01-20-2016, 19:32   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,985
- Start QFIL, Programmer path - browse unpacked ROM location, select prog_emmc_firehose_8916.mbn
- Load XML, select from ROM folder rawprogram0.xml , select patch file patch0.xml
- Connect Phone, Select COM port, Press DOWNLOAD, and be patient until done.
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 02-07-2016, 09:34   #4 (permalink)
Member: 687836
Thanks Meter: 22
i have same problem pls any solution to unbrick lenovo a816
Old 02-07-2016, 14:20   #5 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,985
Yes, solution is to open your eyes and to read thread
From beginning, if needed, over and over again.
B r
Alex
__________________
Old 03-16-2017, 19:19   #6 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 376
sir problem after brick no edl mood9008 only show 9006 driver so never flash any soft help me how can recover
Old 03-17-2017, 01:57   #7 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,985
Open the phone, and take picture of mainboard from both sides.
That's the only way I could show you what to try.
b.r.
Alex
__________________
Old 03-17-2017, 06:58   #8 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 376
b.r.
Alex
Old 03-17-2017, 22:18   #9 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,985
Try attached picture and post results ....
b.r.
Alex
__________________
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 03-18-2017, 16:51   #10 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 376
b.r.
Alex
ok i try then result................
Old 03-19-2017, 07:49   #11 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 376
thanks 4+5 is tp bur 9008 show only 20 sec then out 9006
Old 03-19-2017, 08:03   #12 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 376
[/QUOTE]5843036967613[/IMG]
***** EDIT:
now set is runing use xxxxx only write boot and recovery file under 20 sec then mobile allays show 9008 then flash qfil but restart
***** EDIT:
ur given 2 file A816_A_0017_140928 - VIBEUI_V2.0_1439_ST after black but restart and And another ROM for Chinese A816 - HERE file show lenevo but restart
***** EDIT:
sir when recover mode set never restart but fast boot mood set restart
Old 03-19-2017, 15:51   #13 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,985
Very big probability of eMMC failure.
With one of those two roms, phone must power on,
I reflashed same phone few days ago.
(Working phone, flashed for test),
With one of them - black screen, with another,
It powered on.
B.r.
Alex
__________________
Old 03-20-2017, 05:53   #14 (permalink)
..::One-Man::..'s Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,574
Once perform with eMMC Software Download. 9006 create new drive on your pc
Old 03-20-2017, 06:16   #15 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,985
As I already wrote... it's probably HARDWARE malfunction.
Try to flash it WITHOUT battery, if it still goes to 9006 port,
and drivers are okay, and flashing fails,
last hope is to try on another PC, and if all the same,
well, nothing else to do.
Big question is if even replacing eMMC will help.
b.r.
Alex
__________________
Page generated in 0.52544 seconds with 8 queries
