Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 03-20-2017, 12:31   #16 (permalink)
Member: 773426
Thanks Meter: 8
help, after flash with A816 S017 150206 Multi Language Pack ROM, phone show IMEI: 0, whats should i do?
Old 03-20-2017, 13:24   #17 (permalink)
Vahidpappali's Avatar
Member: 2602890
Thanks Meter: 137
Originally Posted by gilbertz View Post
help, after flash with a816 s017 150206 multi language pack rom, phone show imei: 0, whats should i do?
if baseband ok then rewrite imei back
on your back sticker
Old 03-20-2017, 13:38   #18 (permalink)
Member: 773426
Thanks Meter: 8
baseband ok and root condition, i have to try write, but there is no diag mode in this devices, need more information brother
Old 03-20-2017, 13:50   #19 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 219
change usb driver problem 1000% solve
few days ago i was faced same problem but after change usb driver problem solved
Old 03-20-2017, 23:15   #20 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 3,060
Both flash files i posted, tested on 100% working phone,
Results:
- After writing file from second link - black display on power on, but sound can be heard upon booting.
- After writing file from first link, phone booted up normally,
imei and baseband ok, network okay.
So ... imei problem is not in the rom. Either is a hardware issue,
or already corrupted nvram area.
I attached .qcn backup fixer. You will need diag port enabled,
to make backup qith QPST, and through attached SW to fix imei, wifi, BT addresses.
(try to enter test menu - on powered off phone, hold volume up + power on key, menu should appear, then connect usb cable)
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 03-21-2017, 11:26   #21 (permalink)
Member: 773426
Thanks Meter: 8
work fine in my phone brother Brka,
1. enter test menu (vol min + power on)
2. connetc to pc
3. open qpst configuration
4. look picture above
5. start client/qpst software download
6. bakcup qcn
7. write lenovo s90a qcn (tested work for a816)
Old 04-10-2017, 01:27   #22 (permalink)
Member: 2704773
my a816 not detected on any pc. it can't power on, no vibrate, no bootlop, no activity when plug in to charger..
please help me..
Old 04-12-2017, 21:35   #23 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 3,060
please help me..
Charge batery on external source,
try pressing both volume keys, then insert usb cable,
see if something appears under device manager.
b.r.
Alex
__________________
Old 04-13-2017, 01:51   #24 (permalink)
Member: 2704773
b.r.
Alex
still no result..no change..please help...
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.39703 seconds with 8 queries
