Lenovo c2 k10a40 MT6753 IMEI Repair Help Need Need help. Repair imei lenovo c2! Lenovo c2 k10a40 mt6753 processor! I do not think I'm root for this model! |
You'll need to write NVRAM & NVDATA files for that model in order to fix IMEI and Network, Here is the files: Guide: Code: 1. Run SPFT, Code: After this process your phone will have an IMEI for another phone (The one we got the backup from), If you want your original IMEI, you may want to edit the "NVRAM" file to add your IMEI's HEX values before you write it. |
how to edit? whats is the adress to edit and write back the original imei from the file nvram? |
work perfectly tested with me thx bro |
Hello, I think the question is the same of regisxyb2... You wrote: "After this process your phone will have an IMEI for another phone (The one we got the backup from), If you want your original IMEI, you may want to edit the "NVRAM" file to add your IMEI's HEX values before you write it." Which part of the file I should edit with my IMEIs? This post is so old, but I hope will read and answer... THANKS |
pleas pro can you tell my how ican backup NVRAM & NVDATA from any phon mtk |
k10a40 imei 1 Attachment(s) when I click write memory, I get this, what's next, thanks in advance http://forum.gsmhosting.com/vbb/atta...6&d=1515610999 |
how to load preloader.....? |
1 Attachment(s) Quote:
am trying to follow your guide however when I try to write the first file SPFT is asking for preloader or BL_DSP files. any idea? |
modified scatter flash this package K10e40_nvram&nvdata |
Hello Thanks for your effort, is good to have this info here for others. I solved my problem using xxxxx box, however I needed to hold "vol down" key while connecting usb cable in order for phone to get connected without the SecureBoot |
What box you used? please answer |
This section are not allowed here recommend any professional tools name. Just you can use search button about your problem, that the magic button really work awesome. |
bro its asking for pre loader or dsf can help plz i already put the scatter but also no results |
Simply Load Stock firmware with the scatter of that ROM then write nvram Tested Then restore original imei |
