Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 04-18-2017, 04:26   #1 (permalink)
Member: 1404678
Lenovo c2 k10a40 MT6753 IMEI Repair Help Need
Need help. Repair imei lenovo c2! Lenovo c2 k10a40 mt6753 processor! I do not think I'm root for this model!
Old 04-18-2017, 20:30   #2 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 873
You'll need to write NVRAM & NVDATA files for that model in order to fix IMEI and Network,
Here is the files:
Guide:
1. Run SPFT,
2. In the "Download Agent" section choose "DA_SWSEC_CRYPTO20_K10a40.bin" from SPFT folder,
3. Press Ctrl + Alt + V (This enables Advanced mode),
4. Now go to "Window" then choose "Write Memory",
5. In the "File Path" choose "ROM0_nvram.bin",
6. In the "Begin Address (HEX):" add this value (0x380000),
7. Now press "Write Memory" then connect turned off phone,
8. Do the same with "ROM1_nvdata.bin" but with this value (0x6B00000),
9. Now you can power on your phone and check for IMEI and Network,
##NOTE:
After this process your phone will have an IMEI for another phone (The one we got the backup from), If you want your original IMEI, you may want to edit the "NVRAM" file to add your IMEI's HEX values before you write it.
Best Regards
The Following 12 Users Say Thank You to MiRoOo For This Useful Post:
Old 05-20-2017, 14:44   #3 (permalink)
Member: 2244285
Thanks Meter: 5
how to edit?
whats is the adress to edit and write back the original imei from the file nvram?
Old 06-08-2017, 13:33   #4 (permalink)
Member: 361348
Thanks Meter: 625
work perfectly tested with me thx bro
Old 07-05-2017, 13:49   #5 (permalink)
Member: 2733537
Unhappy
Hello, I think the question is the same of regisxyb2...
You wrote: "After this process your phone will have an IMEI for another phone (The one we got the backup from), If you want your original IMEI, you may want to edit the "NVRAM" file to add your IMEI's HEX values before you write it."
Which part of the file I should edit with my IMEIs?
This post is so old, but I hope will read and answer...
THANKS
Old 08-27-2017, 23:50   #6 (permalink)
Member: 1868510
Sonork: sonord
pleas pro can you tell my how ican backup NVRAM & NVDATA from any phon mtk
Old 01-10-2018, 20:04   #7 (permalink)
Member: 453186
Thanks Meter: 26
k10a40 imei
when I click write memory, I get this, what's next, thanks in advance
Last edited by ...:::::NP™:::::...; 01-16-2018 at 20:24. Reason: Quote has been remove
The Following User Says Thank You to ackom For This Useful Post:
Old 01-11-2018, 11:26   #8 (permalink)
Member: 453186
Thanks Meter: 26
how to load preloader.....?
Old 01-13-2018, 19:10   #9 (permalink)
Member: 220595
Thanks Meter: 258
Here is the files:
Guide:
1. Run SPFT,
##NOTE:
Best Regards
Hello
am trying to follow your guide
however
when I try to write the first file
SPFT is asking for preloader or BL_DSP files.
any idea?
Old 01-14-2018, 22:47   #10 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,205
modified scatter
flash this package K10e40_nvram&nvdata
Old 01-15-2018, 05:49   #11 (permalink)
Member: 220595
Thanks Meter: 258
Hello
Thanks for your effort, is good to have this info here for others.
I solved my problem using xxxxx box, however I needed to hold "vol down" key while connecting usb cable in order for phone to get connected without the SecureBoot
Old 01-16-2018, 20:07   #12 (permalink)
Member: 453186
Thanks Meter: 26
Originally Posted by yurais View Post
Hello
What box you used? please answer
Old 01-16-2018, 20:29   #13 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,866
This section are not allowed here recommend any professional tools name.
Just you can use search button about your problem, that the magic button really work awesome.
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 03-27-2018, 15:07   #14 (permalink)
Member: 2462266
Sonork: www.belezuracell.com
bro its asking for pre loader or dsf can help plz i already put the scatter but also no results
Old 05-30-2018, 13:19   #15 (permalink)
humb11luis's Avatar
Member: 37485
Thanks Meter: 64
Simply Load Stock firmware with the scatter of that ROM
then write nvram
Tested
Then restore original imei
The Following 2 Users Say Thank You to humb11luis For This Useful Post:
Page generated in 0.37770 seconds with 8 queries
