Lenovo k5 Note A7020a48 ( k52t38 ) ROM hello every one i need lenovo k52t38 firmware if any buddy have this file kindly share here thanks advance:rolleyes: |
Available ROM's : A7020a48_S318_161128_ROW - Аndroid 6.0, VIBE UI 3.6, Euro/ROW A7020a48_S312_160926_ROW - Аndroid 6.0, VIBE UI 3.6, Euro/ROW A7020a48_S259_1600721_ROW - Аndroid 6.0, VIBE UI 3.6, Euro/ROW A7020a48_LL_S125_160419_ROW - Android 5.1, VIBE UI 3.х, Euro/ROW archive pass : lenovo-forums.ru http://i.imgur.com/66GZmka.png b.r. Alex |
thanks for your reply sir but i am sure my model is lenovo k52t38 i see model in software and also in back of the cover well i am downloading the file mybe rom work when software done will informed you ***** EDIT : during flashing error and set stuck at logo tool dl imge failed. |
p.s. why did you needed the rom ? what was the initial problem with phone ? b.r. Alex |
lenovo k5 note k52t38 hello sir salaaam,,,,,,,,sir i have lenovo k5 note k52t38 ,,,,,,, everythingis perfact but 3g not working ,,,,,,,, i have about 5 phones all have sam problem any help sir ????????? also try flash but still problem ,,,,,,,, |
check which one you have, they have different basebands, Flash according to model you have. p.s. A7020a48 (K52e78) is model, without Fingerprint Scanner. p.s.2 A7020a40 is model WITH Fingerprint Scanner. b.r. Alex |
i flash with these both firwmare A7020a48 (K52e78), and A7020a40 ROW. but still no network in wcdma,,,,,,,, my Place is Pakistan |
Tested, its working. . |
than those which are in your phone. Of course, if so - nothing can be done. b.r. Alex |
after flash set working fine but bb unkwn any solution? |
br. Alex |
lenovo k52_a48 firmware needed dear brka sir please help me i need lenovo k52_a48 firmware Brand : Lenovo ProdName : k52_a48 ProdModel : Lenovo A7020a48 Device : A7020a48 AndroidVer: 6.0 MTK CPU : MT6755 MTK PRJ : alps-mp-m0.mp7-V2.3_lenovo6755.66c.m_P164 Display ID: A7020a48_S318_161128_ROW please sir need working firmware badly so please help me |
You can "convert" Chinese K52e78 to ROW version with THIS rom. However, BEFORE FLASHING IT, BE SURE TO MAKE BACKUP of nvram and nvdata partitions ! In SPFT - "Memory read" option, add, select save location and file name (nvram.bin) - start address : 0xd780000 , length : 0x500000 again, for nvdata - add, select save location and file name (nvdata.bin) - start address : 0x4bc8000 , length : 0x2000000 ONLY after you made mentioned backup - flash posted rom file. After flashing, IMEI/WiFi/BT/Serial will be gone. To restore it - use again SPFT - press CTRL + ALT + V , Window, Memory write, and select nvram.bin, input same address as for read : 0xd780000 , press write, wait for finish, repeat procedure with nvdata.bin - address : 0x4bc8000 After all done, enter phone recovery menu, make Wipe Data / Factory reset, then Reboot. All should be working normal. test, and post results, also post your copy of nvram + nvdata, may be usefull to others. b.r. Alex |
