Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 07-27-2018, 06:11   #46 (permalink)
Member: 823633
Thanks Meter: 1,688
lenovo a7020a48 dead here how flash here pleae tell me
i am try 3 flash file but eror come here
Lenovo_A7020a48_S312_MT6755_20160926
Lenovo_A7020a48_S318_MT6755_20161128
Lenovo_A7020a48_S420_MT6755_20160928
i am flash tool try but eror come
da download pros 100 not come here proses
*** Edit:
phone alive but
phone bassband unknow imei null
Old 07-28-2018, 20:54   #47 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,072
You may have a Chinese model of A7020a48 also,
Read post #30 in this thread.
Check PM also, I sent you something to try and play with.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 08-23-2018, 20:50   #48 (permalink)
Member: 2473064
Thanks Meter: 12
like how exactly do i have to idenify this model coz it is lenovo a7020a48 with finger print scanner.Guys it is still stuck in dll image even after flash
Old 09-03-2018, 21:01   #49 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,072
DL Image failed is solved by enabling "USB Download Checksum" and "USB Storage checksum"
under SPFlashTools drop-down menu OPTIONS / OPTION / DOWNLOAD
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 01-24-2019, 10:03   #50 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,969
Hello,
already flashed with 2 version
but still same unknown baseband
A7020a48_S318_161128_ROW
A7020a48_S259_160721_ROW fingerprint version
today i searched other phone to read NVRAM backup but phone had 3GB ram
and damaged /Unknown baseband phone have 4GB ram read info same with box
Old 01-27-2019, 21:26   #51 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,072
Originally Posted by syed tuqeer View Post
Hello,
read info same with CM2
Okay, can you take a picture of the back sticker,
upload to some image sharing site (like imgur etc.),
and send me in private message.
It's really hard to guess without such info,
and thus, hardly to say which exact rom fit in that particular phone.
there are flashes for these hardware codes :
A7020a48_S420_160928_TRUE_TH - HW 52
A7020a48_S318_161128_ROW - HW 50, 51, 52, 53
A7020a48_S312_160926_ROW - HW 50, 51, 52
A7020a48_S259_160721_ROW - HW 50, 51, 52
A7020a48_S236_160708_ROW - HW 50, 51, 52
A7020a48_S234_160621_ROW_IN - HW 50, 51, 52
A7020a48_S125_160419_ROW - HW 50
and few lower versions also HW code 50.
p.s. You can try flashing with some of below ROM's, to see if baseband will get back to normal :
A7020a48_S318_161128_ROW - ROW/EU version with FP scanner
A7020a40_S318_161128_ROW(A40) - ROW version without FP scanner
archive pass: lenovo-forums.ru
p.s.2 As already stated before, device may be Chinese version K52e78,
and conversion ROM can be found here : K52e78_china_to_A7020_S318
or
K52t38_USR_ST1610 (with FP scanner)
p.s.3 Useful explanation how to fix imei, wifi/bt/mac addresses, serial number, etc.
How to restore nvram using Maui META 3G and SP META
(use google translate. ALSO - TO BE ABLE TO FIX, when baseband is ok, you will probably need to erase nvram+nvdata partitions)
b.r.
Alex
__________________
Old 02-05-2019, 07:40   #52 (permalink)
Member: 654997
Thanks Meter: 3,969
Hello,
Sorry for late reply
Pics link :-https://www.4shared.com/zip/c9i-upgo...190128_12.html
Tried firmware
K52e78_china_to_A7020_S312_v2
But still not fix (unknown baseband)
Old 02-06-2019, 00:39   #53 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,072
Hello,
Tried firmware
(imei and other text must be good visible, readable easy),
b.r.
ALex
__________________
Old 05-17-2019, 09:50   #54 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 602
before convert
Brand     : Lenovo
ProdName  : k52_e78
ProdModel : Lenovo K52e78
Device    : k52_e78
AndroidVer: 6.0
MTKxCPU   : MT6755
MTKxPRJ   : K52e78_USR_ST1644_5.343.1_1610251523_mp7V2.3_CN
MODEM : k52e78_lwctg_md1 k52e78_c2k_md3
did backup nvram and nv data
flashed K52e78_china_to_A7020_S312
restore nv data and nvram, but no imei ..any help
Old 05-17-2019, 22:20   #55 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,072
Lenovo a7020a48 Baseband unknown, ROM
Post #27. Reflash some of those rom's.
If baseband returns, rest is trivial (fixing imei/sn/bt/wifi).
All you need to see is that baseband appears under settings/about phone/software information
If that is okay - rest can be fixed with MauiMeta and SNWriter.
*** EDIT:
Found some alive links :
K52e78_USR_ST1615_5.518.1_1604171517_MP10V1_CN (android 5.1)
K52e78_USR_ST1626_5.106.1_1606230955_mp7V2.3_CN (Android 6)
Flash it and check baseband. If comes back ... you are on a good track.
b.r.
Alex
__________________
Old 05-19-2019, 11:10   #56 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 602
*** EDIT:
b.r.
Alex
Thanks alot Brka , baseband fine, did restore ime with mauimeta, mobile is alive and working normally, thanks again
Old 05-20-2019, 19:31   #57 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,072
Next thing to try, if you have time to play with that phone,
is to flash that "conversion rom" - K52e78_china_to_A7020_S318
- make backup of BOTH - NVRAM and NVDATA partitions
- flash conversion rom with "Firmware Upgrade" in SPFT
- in SPFT, with CRTL+ALT+V, write memory, write both nvram and nvdata
NVRAM readback address:
- start : 0xD780000
- length: 0x500000
NVDATA readback address:
- start: 0x4BC8000
- length: 0x2000000
when you write nvram or nvdata, no need to input length, only start address.
with this method, baseband, imei and rest should be okay.
b.r.
Alex
__________________
Old 07-10-2019, 09:55   #58 (permalink)
Member: 1153350
Can convert k52t38 or k52t58 model to get FDD-LTE B1/B3 and W-CDMA B1/B5 ?
Both model can get only TDD-LTE B40 for me.
Or it is network hardware alias number.
Or only k52t58 model suit for my country network ? (FDD-LTE B1/B3 and TDD-LTE B40)
Page generated in 0.36737 seconds with 8 queries
