Lenovo General Lenovo phones discussion, firmwares, solution, help |
10-02-2017, 16:43 | #17 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Reflash factory stock rom, Make factory reset on phone, Write qcn file. Post results. B.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
10-02-2017, 17:21 | #18 (permalink) | |
Junior Member Join Date: Oct 2017
Member: 2763691 Status: Offline Thanks Meter: 0 | Quote:
ok sorry but just tell me by ( write qcn file ) do you mean make backup of my own after flashing stock rom and post it here ? or write your qcn backup to my phone after flashing stock rom ? also which stock rom do you recommend ? K53_USR_S116 ? or K53_S218 ??? | |
10-02-2017, 19:03 | #23 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2759192 Status: Offline Thanks Meter: 0 | Only my imei now is not the same. Just in case if i write again the qcn file it will be fine? Or my phone will be format again? But overall my phone is properly working running in android 7 with rooted rom |
10-02-2017, 21:11 | #24 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
phone Settings / ABOUT phone, then after writing QCN file, imei must appear and will be 81111111111111x. Wifi and BT should also have correct mac addresses after that. (You should EDIT qcn file according instructions posted, to get your original IMEI and write to phone, to get full network) p.s. QCN file is readed from working phone, running Android 6.x. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
10-02-2017, 21:26 | #25 (permalink) | |
but IMEI not showing as you said but blank, BT and WIFI no mac address well i want to remind you that i did that big mistake before on qcomdloader ( ERASE ALL ) maybe that's what makes that problem, maybe i need to flash modemst1 modemst2 fsg ??? could that makes them working ? and where can i find them to flash them ? | |
10-02-2017, 22:27 | #26 (permalink) | |
Modemst and rest partitions, you can read from same working phone, or... you can someone to read it for you, from working phone. I have no idea how to obtain them other way, since they are not delivered in factory rom package. b.r. Alex
10-02-2017, 22:40 | #27 (permalink) | |
10-02-2017, 22:50 | #28 (permalink) | |
Example - HERE Or google ... "how to make partition backup via adb" Although, I know those partitions can be readed via commercial boxes. That's an easy way. b.r. Alex
