Lenovo General Lenovo phones discussion, firmwares, solution, help |
12-29-2017, 14:26 | #16 (permalink) |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | marino_oem_user_7.1.1_NMC26.74-31_31_release-keys_oem_SVC Download Flash With This File Letest Stock Rom Last edited by Brka; 12-30-2017 at 03:52. Reason: fixed link |
The Following User Says Thank You to VC_INDIA For This Useful Post: |
02-04-2018, 21:45 | #18 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
and start reading what SEARCH displays. Post merged into existing thread. Read it from beginning. READ CAREFULLY. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
03-07-2018, 05:03 | #19 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Quote: What to do if after flash , imei blank? DL image failed successfully fixed after flash.. but imei blank.. handset has signal but cant make calls and text.. only emergency call.. need help... | |
03-07-2018, 21:56 | #20 (permalink) | |
or you simply flashed wrong ROM file (ie: mismatched model - XT1902-X, X=1,2,3) So, for beginning, first check exact model, reflash stock rom. All XT-1902-X roms: Lenovo K8 XT1902-1 [brady_oem_user_7.1.1_NMC26.51-41_41_release-keys_oem_SVC] Lenovo K8 Plus XT1902-2 [marino_oem_user_7.1.1_NMC26.74-31_31_release-keys_oem_SVC] Lenovo K8 Note XT1902-3 [manning_retail_user_7.1.1_NMB26.54-35-2_2_release-keys_retail_US] If still the same, after flashing / fastboot flashing, there are APDB+BPLGUI files, inside the rom archive which can be used in combination with MauiMeta, to restore IMEI, bt+wifi mac, sn, etc. b.r. Alex
03-08-2018, 10:15 | #21 (permalink) |
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Mine is Lenovo K8 Note xt1902-3 After following this procedure.. Code: Open " flash_tool.exe " and select the Scatter file you in the " Scatter-loading " section. When done, go to the " Format " tab , select " Manual Format Flash " Then fill in and 2 items as follows: Begin Address [HEX] : 0x1a88000 Format Length [HEX] : 0x100000 Then press Start, turn off the phone and connect to the computer, the tool will run automatically and format the FRP partition. When OK is successful Now power On Phone then after flashing with this rom.. handsets imei is blank but baseband intact... ps.. im the first one to fix the unit... it was FRP lock initially and handset has working signal.. |
03-10-2018, 14:50 | #22 (permalink) |
Freak Poster Join Date: Feb 2014 Location: indore
Member: 2120393 Status: Offline Thanks Meter: 238 | Lenovo K8 Note (XT-1902-3) dl tool image fail done Lenovo k8 note (xt-1902-3) dl tool image failed problem comes after frp remove but after flashing with tested file and new mtk tool is done U CAN FLASH IT ALSO VIA FASTBOOT MODE WITH FLASH ALL.BAT, WHICH IS ALSO IN ARCHIVE FOLDER Flash file and tool link: FLASH FILE and TOOL Last edited by Brka; 03-10-2018 at 22:51. Reason: fixed links, formatting |
The Following User Says Thank You to mintu4200 For This Useful Post: |
03-20-2018, 10:21 | #23 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Mobile World Age: 35
Member: 1667884 Status: Offline Thanks Meter: 144 | Done Without Any Facing Major Problem Steps 1)DO All THINGS MENTION IN POST #1 2)DOWNLOAD CORRECT FLASH AS YOUR PPHONE ( THERE IS 3 VERSION IN K8 NOTE XT1902-1 2 3) 3) NO NEED TO FULL FLASH ONLY SELECT CACHE IMAGE FLASH THE PHONE VIA FLASH TOol 4) ALL DONE FRP REMOVE |
The Following 3 Users Say Thank You to gsmrocker For This Useful Post: |
